@ ALL : Could be that you all are right, about that bios boot problem - MoBo boots (when Bios checking hardware for first few seconds on AUTO settings (bios boot_block defaults) & only than a bit later applies settings determined in Cmos; many boards arround have this issue as I see ... so previously set multi/Fsb/core_frequency & Vcore are not engaged instantaneusly first moment!
Guys, Abit & their Bios manufacturer made stuff to be safe for use for normal users (NOT OC-ers eXtremes), so do not think that there would be available some "enhanced" bios uppgrade for you from them! You need to find someone else really capable to hex_edit the bios code & prepare you a "hacked" Bios for your purposes to re-flash the MoBo resolving certain problems. IMHO this would be the best way.
The next "safest" way would be to try that "dirty Vid Pin wire trick" on P-M socket/Cpu to trick the MoBo of higher boot Vcore if works. If does not, the next step would be leaving that dirty wire mod trick engaged & again reflash Bios with the same Bios version. Could happen that then you will be having a default Vcore higher than before & could be raised in bios even more (maybe up to 2V-attention!-too much!). This trick worked many times in the past, maybe will work also here. Here you have an mine example of tipical FlashBoot diskette ready to be than custom modified if works for you (read_me inside,file): http://users.volja.net/jerman55/FlashBiosFD.zip
The third "safe" way would be that my mentioned Hardware way Fixing Vcore on the MoBo. But that also involves some reading & knowledge too: Vcore Mosfets on the MoBo are driven by an output of 8-bit input digital PWM chip there, which gets combinations on its state binary pins by another smaller digital chip, which gets serial data on MoBo´s i2c (SMBus) data link from Bios (that last chip on old boards with only jumpers or microSwitches for Vcore wasn´t there needed)! Find searching on Google datasheet for that mosfet driver chip on your MoBo, to know which its pins to solder (or terminate with pull_up/down resistors) to a 8-way microSwitch setup. (not sure if w/o need for cutting traces near that chip on MoBo will work, maybe will!). So instead of controled Vcore by Bios, you have a set of switches, which is IMHO better than have on MoBo totally fixed just single Vcore! So that microSwitchSet controls the input logic states of a Mosfet driver chip to procure "right" Vcore to the Cpu!
The forth "safe" mod would be that (added later in my last post on previous site) "PwrGood" trick; see an example picture on my site under comp/mods, how I did similar stuff for Tuallies; the wire is fixed with transparent sellotape & goes shortly into a hole of an orange isolating small tube used for isolation not to tuch internal contacts base (to prevent any electrical shorts-"Electronics runs on Smoke; if it comes out of it, its a BS !") :D :D :D ... You better practice modding/opening socket before on some dead slotket/socket/MoBo, to make it later "tiny", nice & clear & not "dirty"! Do mods on the table not already mounted inside PC!
The last one less safe is the first socket/2-pins mod I proposed (VssSense+VccSense), but you have to study yourself datasheets further before attempting that. I hope that you know, that all these my modding ideas can be tried at your own risk, nobody guaranties you success & many times things can go "south"; sh1t happens! :) But usually people with guts have at least some success (not always)!
Further ideas for better OC will follow maybe already today later !
Regards, Spajky, the "member of Silent computer owners Team" ... :)
