I am running raid 0 with F8f but only with 2 Velociraptors
Hey guys,new OCCT 4.0.0 beta is out.
http://www.xtremesystems.org/forums/...16#post4790516
Why is the GIGABYTE GA-P67A-UD7-B3 deactivated on newegg instead of sold out, etc.?
thanks dude . . . now i gotta take this thing apart tonight , times like these i hate watercooling lol
hopefully cause there trying to meet there deadline of rma for exchanges for B2 to B3 , I hope intel is paying them more while they lose sales to exchange out boardsQuote:
Intel Core i7 2600K @ 5.04 GHz (4C/8T) = 105 X 48
Gigabyte P67A-UD7 B3 F3C
2x2GB G.Skill RipjawsX 2133C7 @ 2240Mhz 7-10-7-27-1T
2x MSI GTX580 SLI, 930/4100Mhz
Corsair AX1200
http://i458.photobucket.com/albums/q.../105x482-1.jpg
** cpu-z reads vcore wrongly.
http://i458.photobucket.com/albums/q...K/105x48pi.jpg
Yeah,very good OC on +33C,same as me.
Only AIDA64 outdated.
thanks andressergio and stasio.
look at the vcore and temps.. it is not possible to run higher anymore.
now all i want is just a better CPU. if anyone had extra 2600K (low volt, high multi >54x) and wanna let go, pls let me know.
stasio did you know that AIDA64 runing as gadget on the background made my SLI loose fps and stutter when i use vsync ? so far i was searching for another hardware problem but as my tests are accurate i realized it was my same ever gadget and aida64 doing it...
i had frame drops with VYSNC ON to 55 and 57 = stutter now i got as it should ! on a SLI of GTX570 rock solid 60pfs
just to let you know and i made other guys test and it does the same
cheers !
Sergio
You can talk about this with Fiery,here:
http://forums.aida64.com/
Try this:
CPU-Z 1.57.2 -for Asus
ftp://ftp.asus.com.tw/pub/ASUS/misc/...asus_setup.zip
Try this:
Use hwinfo32, remember?
If you wanna use the PCIe x1 slot I confirm this works with my HDTV tuner:
http://img.auctiva.com/imgdata/0/4/2...64114865_o.jpg
Nice extenders. Never knew those existed.
And I'm not running afterburner, since my GPU won't go higher than 950 mhz at 1.25v anyway without SUPER high fan speed (not going to try more vcore, proabably hit a wall).
With those extender cables where do you put the card? Hide it behind the motherboard tray or something?
Having useless x1 slot and using pcie x1 card in pcie x16 slot was bugging me. Now I fill better.:up:
Same slot just seats higher.
Got 58x to work for the first time ever with B3 today.
With sub zero though, couldnt even get into windows with 55x on H20. Seems B3 is very picky with temps compared to B3.
B2 pb was 5767, got to 10Mhz less with B3 http://valid.canardpc.com/show_oc.php?id=1731535
Hell of a lot easier to work with. No more BIOS corruption and pretty much anything will POST at the minimum.
