^^+1
Nice find, I updated the link in the OP. :up:
What's your suggestion, then?
I can't think of any way to verify that AVX is being used.
The only thing I can think of is splitting the 5GHz club into "Over 100 GFlops" and "Under 100 GFlops".
But can a 5GHz i7 2600K with HT enabled produce more than 100 GFlops using the latest (10.3.2.005) Linpack?
I can't afford purchasing SB any time soon, so please test this instead of just bumping the thread. Thank you.
Configure LinX to run on 4 threads only. This should increase stress levels (slightly) and improve GFlops output (significantly).
And yeah, that's valid (for SB only, though).
I have some very helpful members giving me feedback right now, and it looks like this scenario might be the way to go for SB testing. :yepp:
Still investigating, though.
It's not really 54%, it's just not using HT. It is pretty much maxed out. :yepp:
almost there, I just can't believe the temp difference:shrug:
either way it is cool to see 120 gflops:clap:
http://i52.tinypic.com/34yw5rc.png
so in other words HT is still bugged with this release?
i7 980x Batch 3040B404
Gigabyte X58 UD7 Rev 1.0
4GB Mushkin RedLine PC3 12800
Air Cooler - Megahalems - P&P Ultrakaze 3.000 RPM´s
http://img38.imageshack.us/img38/8015/lynxxs45.jpg
I have problem with stable my cpu i7 980x 4.5Ghz. These are my settings in BIOS:
Cpu vcore: 1.435V
Cpu Vtt: +300mV
Dim voltage: 1.65V
Ich Vcore: 1.1V
What do I need to change that my cpu stable?Please help
Batch from the CPU for the List is L050A863 plz edit it thx :up:
http://www.abload.de/thumb/5000_1352_linxrgmw.png
Asrock P67 Extreme4
Air on Thermalright Silver Arrow
Batch: L041B789
S/N: 2L040030A2691
Great effort, everyone! Keep pushing! :up:
Now that's a proper run! Time to say "Damn, that's awesome!" :D
Please read the rules. You need to take a screenshot while LinX is still running.
Done! :up:
Play with CPU PLL, IOH PLL (can undervolt these); may also need more QPI PLL. Try PCIE @ 101MHz. Play with CPU Impendance and QPI Signal Compensation if you have these available.
@ everyone:
Rules haven't changed in regards to using all the memory you've got.
You don't need more than 1GB of memory for OS and applications. Enable Page File. Do a short LinX run to free up some RAM. I don't want to see 2GB LinX runs with 4GB of RAM installed any more.
Thanks. :up:
Also... I have addressed the AVX issue, I think. Please refer to the OP.
And the last thing... Need a colour to highlight Asrock boards. Suggestions, please? :)
An option would be to use Orange for Asrock and DarkOrange for ASUS... But I am not sure I like it...
http://www.abload.de/thumb/5000_1424_linx_avxycpi.png
Asrock P67 Extreme4
Batch: L041B789
S/N: 2L040030A2691
This time with SP1 / AVX enabled.
I can tell that LinX w/ AVX is really intense... 160W, just insane as you can see on temps too :\ also had to bump vcore up a good amount... just gross ;)
You need another color for Asrock though... hard to distinguish from Asus!
Thank you :)
Just compared temps.. 75°C max vs 92°C max - just sick :D
This is a list of colors you used, hope I didn't miss one...Quote:
Yeah, I know... :(
Care to suggest one? I am out of ideas.
Foxconn BloodRage
Gigabyte P67A-UD5
MSI Big Bang-XPower
DFI LP UT X58-T3E8H
Biostar TP67XE
EVGA Classified E760
ASUS P8P67 WS
Possible colors for Asrock could be:
Asrock P67 Extreme4 - darkgoldenrod
ASUS P8P67 WS
Asrock P67 Extreme4 - sienna
ASUS P8P67 WS
Asrock P67 Extreme4 - indianred
ASUS P8P67 WS
I like sienna best out of those three :) Readable and slightly distinguished from the rest.
Looks good, thanks! I'll wait a bit for some more feedback and go with the most popular option. :)
Also, could someone please add the following tags to the thread: "5ghz" and "100gflops"? I reached my limit, unfortunately.
@ zalbard
Already did the 5GHz + 100 Gflops with my good chip. Here. My second chip will do it but not on air. Third loop in Linx "4C 4T bios" was already 95 deg @1.44+.Vcore :eek:
And people are telling about Sandy Bridge running so cool... :rofl:
I think we've found the new 'difficulty barrier' which is 5GHz with AVX on to replace the old one (4.5GHz for 45nm chips). I'm kind of glad about it, 5GHz seemed a bit easy-mode and not worth bothering with a club for without AVX. Now the challenge is officially back! :D
Bump for this! More feedback before I go with "sienna" option, please.
Bump for this also. :p:
It's brought back to life and replaced your current non-AVX submission. Nice job, and thanks for pointing it out! :up:
Sorry for the double post, but it's worth it! ;)
We have a new Club logo thanks to our own member oZZy_tv! It's updated for 5GHz Club, uses a fitting Intel's font, and has an improved colour scheme! :D
Check out the OP. :up:
