:eek: oh my! you guys geting speeds of 3GHz+ must have stupidly fast pcs.
Ive only managed to get 2.5GHz out of mine so far :( Though I am hoping to get higher speeds after a few more RAM tweaks...
:toast:
Alec
:toast:
Alec
Ey,
I got this 3000+ winnie CBBFD 0437 VPCW - Have you heard of that stepping, and what is the average clock results ?
Here is my overclock. I can get to windows and get errors in SuperPI at as high as 2.78Ghz, but this is what i run day in day out, as it is as stable as can be. What i like is my voltage is just as low, or lower, than the original settings. Funny thing is, i can go up to 1.75v and it still wont be stable for benching at anything past 260...
BTW, this is on stock cooler with Ceramique instead of Thermal pad. Winchester core, 0441 model.
Newegg.com retail purchased 12/14/04
http://home.comcast.net/~orangeparktech/screenie.JPG
Wow system temp 6C colder than CPU temp. Try cutting down on that system temp and youll improve quite a bit. Nice OC with that voltage BTW!
dont know how to post screenshot, but have my week 35 winnie at 2.5 at 1.65vcore, unsure about temps, but seems to be ok with xp-90 on there, and got my old trusty geil running at 227 @ 2.5-4-3-10, and its pretty good, although having some issues with counter strike source, working on figuring them out.
Oh yeah, with x700pro@ 500/1080 or so I am at the top of the x700's on ARC and ORB '05. Top 5 in x700 in 01 and 03.
Superpi 1m @ 2.5= 34 seconds
stelleg151 you take a screenshot by pressin the printscreen button on keyboard and go into paint and paste, save and your all set.
So what does that system temp do for me? I could always put some ceramique on it, but im not sure if it would make anything overclock any higher or not.
Lower system temp...lower cpu temp. Or is your MB just laying on the table? Whats the usual ambient temp of the room?
Damn, i just dont get it ...
How can u go so high with so little vcore?
My 3000+ will only do ~2520mhz at 1.6vcore :(
No its in a case. This is a 24/7 PC. Im going to try some AS5 on it soon and see if i can push this CPU further afterwards.
and K32A, i just dont know, can't explain it, but it works...lol...Maybe my CPU is able to go higher and my chipset is really just needing to be cooled better. Ill try some things within the week to see.
3000+ w/55's Box HSF 14° Ambient
http://pageperso.aol.fr/misteroadster/28s2915.JPG
http://pageperso.aol.fr/misteroadster/Winnie3072.JPG
Originally Posted by Joe_Beasley
Yeah, well im also using the stock cooler, so maybe i have to buy a better one :)
Im using stock heatsink with ceramique. Try that first.
misteroadster@ , great cpu.... :slobber:
code?... :rolleyes:
3000+ 0448 SPAW
Max screen improved , WR (AMD aircooled) :)
http://pageperso.aol.fr/misteroadster/WRaircoolmini.JPG
Just managed to run 3d mark 2001SE on my 3200+ when overclocked to 2.4GHz.
http://host366.net/pics/overclock/omfg.JPG
Now aiming to see what the highest speed I can get out of my chip for SuperPi. I have passed the 2.6GHz barrier now. Shall try got 2.65+
Alec
Huh, 22°C CPU 25°C System? Is this with an Neo2?Quote:
Originally Posted by misteroadster
Btw, great result! :toast:
no , K8NXP SLI , case temp is always 25°.
Ah ok. What was the ambient-temp. to get 22°C?
About 8°C
The max. i can manage with "normal" roomtemps. It's with "open-window-mod", but watercooling doesn't takes an effect from it, just sys-temp. ;)
http://people.freenet.de/funkflix/3018mhz.jpg
Which AMD aircooler fx-55?Quote:
Originally Posted by =[PULSAR]=
yes ,mister roxx :up:
FX-55 box
+ open window
HIGH-CLOCK
http://www.biwa.ne.jp/~yok/
thanks over :toast:
:slobber: air ????Quote:
