I love it, fast and clean :yepp:
Malik: Great drain idea && great vid. It's win win win no matter how you look at it. Fast, simple draining, more simple tubing to not implement overcomplified draining extras and cheaper because of that, +more flexibility in component placement. Hats off.
Malik! Dentist, that's an awesome video!!! Thankyou!
You can do the same without the pump... just suck on one end of the tube and it should come out pretty easy. Can't wait to see the YouTube vid.
nice video. Loved it especially when you blow the liquid out. Practical.
How often do you keep on pumping the liquid out every month? It seems to me that the reason you loop is without a clot is due to draining liquid and putting back in every now and then.
GPU, VRM and CPU temp please?
It is amazing you're cooling so many components with only a 120.3 rad.
Yuck!!! You blow the tube? Did you drunk any coolant in the process? lol
Phil
Hi Malik i,ve been following this thread for a while now your work is awsome and has inspired me to build a new rig. My most favorite setup you did was the bloody red. Through this thredad i have been able to track down Barus who i have asked to make me a waterblock and qpi.Just like to thank you. Nice one mate.
You have a great looking system. :yepp: Very clean and tidy. Love the icy blue coolant, goes very well with the overall colour scheme. :up:
Great video too. Such a simple and easy method for draining. Awesome mate. :)
In my opinion, it's the best revision of Your project :)
Congratulations :)
I use this pump since 2 years ... belive me this is great and fast system :)
Some new shots ... i will change something soon ;)
http://www.abload.de/img/dsc03425bdew.jpg
http://www.abload.de/img/dsc03427zhzy.jpg
http://www.abload.de/img/dsc03430cdp8.jpg
http://www.abload.de/img/dsc03434tfhy.jpg
http://www.abload.de/img/dsc03435gdt3.jpg
http://www.abload.de/img/dsc03437sgjc.jpg
http://www.abload.de/img/dsc03441ng37.jpg
http://www.abload.de/img/dsc03442yd8q.jpg
http://www.abload.de/img/dsc03443ofm3.jpg
http://www.abload.de/img/dsc03445rf2j.jpg
http://www.abload.de/img/dsc034495grf.jpg
http://www.abload.de/img/dsc03450pddl.jpg
http://www.abload.de/img/dsc03451sdp1.jpg
http://www.abload.de/img/dsc034525dd9.jpg
http://www.abload.de/img/dsc03456behq.jpg
http://www.abload.de/img/dsc03457xgh2.jpg
http://www.abload.de/img/dsc03465mc6t.jpg
http://www.abload.de/img/dsc034680ddl.jpg
http://www.abload.de/img/dsc03470ac1f.jpg
http://www.abload.de/img/dsc03471oe1w.jpg
http://www.abload.de/img/dsc03474l02t.jpg
http://www.abload.de/img/dsc03475c0hm.jpg
I remember correctly, Malik, you were planning to get a new case and start on a new project. Correct me if I am wrong.
Which pump are u using ?
What about flow ? l/h ?
Do u still have aquaero ?
thanks !
great work btw
What liquid do you use?
Your tube bends are 2nd to none, niesamowita praca mój przyjaciel.
what about tube bends ? I don't understand ;)
Some little changes on way...
http://www.abload.de/img/dscf1676jz1s.jpg
Lol, I tried some polish, just said they looked great.
