Originally Posted by shmadz
I was having all kinds of weird problems that I blamed on this board, but I think I may have found the real problem so I thought I'd share.
My issues have been strange and somewhat counter-intuitive. Prime stable 8 hrs overnight and then crashing in two seconds at lunch. Stable all night friday and then won't even boot on saturday. Also it seemed like more voltage was making it LESS stable!??!
For example I would start to OC the ram at stock volts and 3-3-3-8 and it would go to 240 and then start to see errors. Not bad, so let's up the voltage and try to reach 245, 2.65v - nope, 2.7v - no, 2.75 - nothing. I tried loosening the timings but no luck. The really weird thing was that at 2.7v I would see errors at much lower speeds. It even corrupted windows, twice. I would set a conservative overclock that should have been stable(9*260 with ram at /166) and start priming and go to work and when I get home, black screen and windows will no longer boot at any setting.
I noticed that the voltages were really fluctuating but I didn't worry too much cuz many were saying the same, but what really made me think was the fluctuations increased when I enabled cpu over-voltage when most agree that it improves the situation(decreases fluctuations). So I started paying close attention to voltages and I verified that when I add voltage to ANY setting, my stability goes down... I have a 600w PSU so I start blaming the board and getting real mad and trying to figure out how to RMA or if I could swap for a DFI or something... and then I read Ic3man's prophetic words from like 20 pages back... "check everything"
So then the light comes on and I take one of the really expensive powerbars from work and plugged it in and guess what, "site wiring fault". I checked all the plugins in my apartment and of course the only one that lights up red is the one by my desk :cussing: Now, I haven't had a chance to test fully but the voltage fluctuations have diminished and early OC efforts are bringing much more normal and predictable results (2.6v=240 ; 2.65=244 ; 2.7=250+ haven't gone past 250 yet)
I really should have realized the problem earlier, but my old P3 ran on that plugin without any problems, so I didn't think it was the power. In hindsight the P3 probably draws 1/5 of the current of my new rig so the voltage problems most likely weren't showing up under light load. I'm a little worried that the dirty power affected lifetime of my hardware (mostly the ram and mobo chipsets) but mostly just happy that everything now works.
:party: btw, the board is a beauty, some quirks but that just gives it personality.
