Max Multi is 55.....
Here my settings for 5Ghz
for over 5 Ghz i go to LLC 75%,Phase Controll to extreme,VCCSA 0.950V,VCCIO 1.1V,PLL 1.8V and the rest the same on my screen.
http://www.abload.de/thumb/1883x.jpg http://www.abload.de/thumb/2gm8c.jpg http://www.abload.de/thumb/3z8jh.jpg
3102c187 max multi 54
asrock xtreme6 vs Gigabyte UD7?????
I have 2 x I7 2600K one can x55 but max is x54 on water, and one that can x57 but here is the max also x54? on water,same voltset must use both CPUs, funny enough:confused:
may be my motherboard will not anymore, have looked a little on hwbot, and again Regt run over x54 in 3DMark tests Asrock xtreme6......
Is Gigabyte UD7 so much better to overclock ??????????
ok ty
Efficiency wise seems GB still has got the upper hand in 3D01 and 03... I don't need really that much more Vcore , in fact the UD5 requires even less ram voltage with the Hypers then on the M4E... (and no it doesn't overvolt :p)
Each board has it's strengths and flaws...
Mayeb you can try the new easytune, didn't it have XX values for loadline ?
Easy tune requires intel drivers right, can they be uninstalled safely?
2600K L042A969 #0465
http://img844.imageshack.us/img844/6...hz162v32mb.jpg
Does command rate have any effect on the required Vcore for overclocking ?
I am so unlucky with 2600K...
Air cooling / UD4 B3 / Bios 1.55Vcore LLC Enabled
Batch# L044B694
S/N:0610
Max mhz: 5281
S/N:0864
Max mhz:5281
Batch# L044B682
S/N:1977
Max mhz: 5181
Batch# L044B676
S/N:3082
Max mhz: 5200
I've been getting round off errors trying to get 4.8Ghz stable, this starts from 1.440vcore upto 1.470 ( highest I've tried ) I have the RAM at 1333Mhz 9-9-9-28-1T to rule out ram issues. I've tried running my RAM at XMP profile ( G.Skill 6-8-6 @1.5 1600Mhz with HCI memory test 1000% coverage and 2 loops of Memtest86+ )
I have LLC enabled and all other voltages in auto, this error pops up after 2-3hrs.
Nice chip and score there angkies.
Some also have reported that on their MIVE it takes +0.050 more voltage to get the same clocks as compared to what Gigabyte needs, I think its all in the luck of the draw for the CPU. Each mobo delivers power a little bit different so some CPU's might work better with Asus or GB. But I've heard a lot more people that with the Asus board they require lesser voltage.
3101a201 *a3322 55x - 5.55Ghz. wall
3101a201 *a1374 53x - not bother to test Mhz. wall
#L050A853
mine max multi seems x54 but MGHz wall its above that
http://img828.imageshack.us/img828/5582/p1090445.jpg
http://img696.imageshack.us/img696/7316/54001.png
Uploaded with ImageShack.us
Guys, slightly OT but still relating to SB clocking - what are the best 8GB (2x4GB) rams to buy with highest clock and best timings? I had a set of ripjaws-X 2200c7 but sold them to move try a 970 but now Im looking back at SB again.
zsamz - by your sig you own both atm, how much difference is there in benching between a good 1366 near 5ghz with good rams and your SB setup? Im mainly doing 3D11 and 06 with some vantage and the odd earlier fm.
Cheers.
