Thats the 3006A442 chip. CB around -150 That was as far as I got before we last talked. Haven't tried anything further yet. The 3003B208 has not been tested and the 3003B396 was sold off last month. I'll post back when I make some progress.
5 years from now, what price of the i7-980x will be?
Awesome man!! :D Just did a 6100mhz 3dmark 06.. Only at 1.75v as well... Pretty sweet!
You know whats weird about these two chips I have. I dont mind it but I have to set the vtt on both of them to 1.50v or higher for them not to cb.. Otherwise I get cb at -150 / -160 or so..
vtt at 1.50v and no cb.. -185c!! :D
Just got a 3013A(489) from rma land. No cold juice till monday
I didnt think there were anymore 3003Bs around? Hmmm maybe I should check again some of those A batches look good
Hey Splave, Let us know how the new chip clocks. Cant wait! No juice for me til monday as well..
Is it expensive for L2N liquid ??
No CBB with new 704 BIOS! Can boot direct @ -180C :up:
Just waiting for higher efficiency BIOS! ;)
Heheh dont the A0 rev 980s clock higher but arent as durable ;) but 5K uncore oh my...
Hey Tintin, Really nice! :) Did you notice anything weird with that chip after disabling cores though?
Sup, guys.
Just wondering if I can pull off 3-way SLI GTX 480 water cooling with an NIC on the mini PCI-e slot and a sound card on the gray PCI slot?
http://img94.imageshack.us/img94/6697/rampageee.jpg
Only if the water blocks are single slot blocks. You can check the Koolance or the EK, but I am not sure if they are single slot or not. You would also need a single slot PCI bracket to replace the stock one. Not sure why you would want your own NIC and sound card as the onboard options are pretty sweet.
Well, I use headphones, so, the PCI sound card will give me a higher volume. My current sound is maxed out and watching stuff like the Office on Hulu comes out pretty quiet.
If the PCI NIC will give me a split-second better response in gaming, it'll be well worth it. A lot of those battles are won in a split second! Just think of when you're going to knife someone that's going to knife you.
In Belgium it's about 1.5 dollars/liter, 40 Dollars for a few liters is darn expensive in my book...
I would give the onboard a shot first, before cashing out. If your ISP is inferior not even the most expensive NIC will help you. A good gamer can compensate for a few ms of lag...Quote:
I'm currently using the R3E onboard sound, it's fine, it's just quiet.
My ISP is fine, however, there's a wireless router hooked up to my wired portion which seems to slow things down just a tad when other members of my household are using the wireless connection.
hey guys! figured i'd give my offering with a 930 before the 980x goes in; in a few days.
this is on water... well liquid cooled atleast with koolance fluid. the best i can do is 21x210 ratio on 0704 and 0802 bios versions and 213 seems to be the peak stable blck for the 930 for the moment on my board.
anyway, here it is. sorry in advance for the image size, seems every time i try to trim it down a bit, everything blurs out for no reason :shrug:
actually i'll just keep it in link format:
http://i3.photobucket.com/albums/y71...930results.jpg
Hello there to all.
I want to ask if anyone have check the voltages with multimeter or with rog connect and if so how they are.
Thanks in advance
I would say that L2N is pretty expensive. Never heard of that one. :D LN2 is pretty cheap though.. 35 dollars here for 35 liters..
Here its $45 to fill the 50L (It use to be $20) & $20 for 35lbs of dry ice.
