Nice to know Clint. 4Ghz @ 1.2v is very good. Lap that True Black (not sure about the cpu though :P ) and push it some more :)
Damn it ! Man get yourself some water cooling stuff and overclock your CPU to 4.5 NOW
Batch 3931A
1.3vcore bios (1.264 cpuz)
21x191 20 linpack / 12 hr prime stable
920 3941B076 11/11/09
200x21 4.2GHz @1.3v
linpak64 stable
ucore realy doesnt like anything other than 2x ram
probly anus's regulation to blame for that though
Later i will post da batch, now i have some screens:
Asus R2E
920 D0 BATCH #: 3849A765
OCZ Reaper 15000 3x2GB
EVGA 260 GTX SSC
PC Power & Coling 750W
http://img691.imageshack.us/img691/9...tasusprobe.png
http://img69.imageshack.us/img69/1668/linx30min.png
Some 3D results:
http://img32.imageshack.us/img32/582...k200622193.png
I have water cooling in the cpu and in the 260GTX.
Enable HT, you will get better score in 3DM06 ;)
i think i dont have any advantage to have HT on for gaming, because of that i dont have it enable, but i will try, thanks for the tip.:up:
Hi wanted to add mine too Batch 3836A288
http://img94.imageshack.us/img94/756...d440566620.jpg
HT gives performance gains but also makes your processor run much hotter. Unless your temps are very cool right now I would not recommend enabling HT. I have a 3942A, I'll post OC later.
Foxconn Bloodrage GTI
G.Skill DDR3 1600 8-8-8-24 1.5v
Stepping: D0
Batch: 3942A
Reseved (I'll have it done by end of week)
post updated, my 920 batch is 3849A765.
I dont now why but when i pass 214 blck my 260gtx have some problems in 3D, 4500MHZ is very nice overclock :cool:
Depending on your board, try setting your PCIe clock to 101 instead of 100.
I'll be looking forward to you're results. I have a 3943A D0. If you can, mind listing specific numbers, qpi/vtt & etc. I'm still waiting on my cpu cooler & probably won't be until late next week :(
Thanks in advance.
edit: I'm glad you guys are pushing more than 4GHz; once I hit that point of 4.0GHz I'm done. Maybe shoot for lower vcore, but 4.0GHz is what I want, nothing more.
Sold my 965 EE, got a 920 3943A521.. are these good batches ?
whats the consensus on the 3941B045 Batches?
CPU: i7 920
Stepping/Revision: D0
Batch: 3942A
MOBO: Foxconn Bloodrage GTI (BIOS: P09)
4.1 GHz (210x20) @ 1.36v LinX 100+ pass stable http://valid.canardpc.com/show_oc.php?id=906494
I think I could get by with 1.5v just fine or even 1.4 but I am working on getting up to 4.2 GHz right now so I went ahead and set the voltage up a bit.
Overall, this isn't the best chip out there but it will serve my needs just fine. Temps stay well under 70 running LinX, the hottest core stays around 60 running P95 Small FFT. Basically, :up:
CPU: i7 920
Batch: 3942A497
MOBO: GA-X58-UD4P
http://i46.tinypic.com/14917p1.jpg
And will do 4.0Ghz at 1.3V
