Originally Posted by
Robin77
Than you had low quality boards for your studies. My NB runs even idle on 67 C and my PC runs round clock (cause of downloading ;-)). I've not a single stability issue or even anywhere near.
As said, look at what Intel says what is the max temp (96 C) and look again what I wrote regarding my NB tems and the rockstability with it. Believe me, if you get issues with low NB temps of even under 60 C then you should really RMA your board, because the NB is built to run rockstable up to 96 C. This is not a peakvalue for jus 1 sec or so, it's the max. value for longtime usage.
