Hi,
I have the system in my signature, and without detailing it, my P965 won't give me 1MHz above 390 FSB, even after NB strap change at 401MHz and above, whatever voltage settings/timings/number of ram modules... I try.
It is, exactly the same limit with my previous Q6600 B3.
I looked on the main topics of P35 and X38 boards, and it seems the Maximus is the way to go.
The >1.5vcore bug with quads is bizarre though. As it presents, it could be a hardware issue. I won't like to spend so much money and sit at 3.6GHz because I can't shoot my G0 with some elctric shocks :explode2:
So I have some questions if you can help me:
1- I'd like to be sure of that >1.5 vcore issue with quad cores. Does-it mean, no OC above 1.5v?
2- Also, any one tried the graphite mods if they fixed this issue instead of maybe a buggy PLL bios setting?
3- When OC the Q6600 above 3.8/3.9GHz, so very high FSB for a quad, what temperatures are going the NB and SB while using Prime95 Large FFT, or better, OCCT last beta in RAM mode with the stock cooling (passive)
4- I have two HR-09U and one HR-05 IFX for cooling the mosfets and NB. I could add a HR-05 IFX for the SB. Is all the heatsinks soldered with the heatpipes or they can be unmounted separately. As the X38 is known to be hotter than a P35, is the passive cooling on the MB or even a NB watercooling enough to cool the mosfets and NB on a highly overclocked quad? (I mean above 1.5 vcore and 3.6GHz)
Many thanks for all owners of the Maximus giving feedback for future users
