something to make you laugh
I finally get around to testing my Conroe 6400 and P5W DH, I install the board and the stock cooler as usual to test temps on stock, and then go to power-up the system and nothing?
So I check all connections blah blah, and try the obvious removing the conroe and installing a Pentium 930, still the system won't power-up?
So I pull the board out of the case set it up on the box on Anti-static bag to elinimate Case grounding problems etc. as an option. I use a jumper to power up the board and it works! So I pop the front off the NZXT Zero case to see where the short might be in the wiring and it's fine? Then I realize I was freaking trying to power on the system using the DAM Reset button Doh!!!!
I've decided to remove the "savant" from my nickname Idiot-Savant. Anyway I rei-install Conroe she boots but it says 6300 running at 1.60GHz? So I raised the FSB to 333 as I thought this was supposed to be the Conroe's FSB speed anyway and this raise the memory to ddr2-1000 ehifch it is, and the chip to it's dfeault speed of 2.13GHz> Then the system won't boot? When the BIOS (0801) comes up again (at 1.60GHz) I notice the CPU temp is 65C? I try lowering the Vcore which was on Auto but I figure maybe there's something wrong, and this does nothing. Now I know with stock cooling 65C is insane since my room is at 18C and the case is open and near an open patio door letting cold air in. SO 65C is impossible. Well not with a Pentium 930 and a stock cooler overclocked but on a Conroe running under it's speed? PLAESE HELP
Does the bIOS 0801 report CPU temps wrong?
I'm sure I seated the cooler correctly although to be honest I hate these freaking new pop-pins they drive me nuts because they just don't work right half the time. You push two pin across from each other so one side doesn't seat unevenly and what happens only one goes in anyway. Anyway I need help or a handgun..... :(
