Where is DosDuoNo with the big 1 day left sign, I was looking forward to it.
Nvidia made way too much of a big deal to NOT have this card ready and out tomorrow (Friday)
GTX 470 gets listed.
Bazoom!!
http://img268.imageshack.us/img268/2135/gtx470.jpg
:eek:
any price yet on the gtx480
XFX GTX480 specifications Core frequency 625 (MHz)
Unless this is a typo we might see two versions of GTX480, with Core frequencies 625 and 700 MHz
Maybe 625MHz is ROP/L2 clock.
XFX GTX470 specifications
No price yet though
less then 12 hours left
Why would there be two different clocked versions for the GTX 480? Maybe review samples will be different than retail boxes? I sure hope not.
All of them? :ROTF:
Seriously though, the last thing we all need is cherry picked cards for reviewers. I doubt Nvidia is going to do this, would be PR suicide. I just can't believe that the NDA lifts in a few hours and we are still not sure of the final specs.
XFX GTX480
Graphics Properties: Desktop-class
Display Chip Type: GeForce GTX 480
Display chip series: Nvidia GeForce GTX 480
Memory capacity (MB): 1536
Memory Interface (bit): 384
Core frequency (MHz): 625
Graphics core code: GF100
Chip making process: 40 nm
Interface type PCI-E
Memory Type: GDDR5
Stream processing units: 480
Memory Package: FBGA
RAMDAC: 400MHz
XFX GTX480 function parameters
Support the maximum resolution: 2560x1600
Full support of DirectX: DirectX 11
DVI: Dual 24-pin DVI-I interface,
Video support: mini HDMI
Heat dissipation: Fan + heat sink
3D API: DirectX 11
XFX GTX470
Display Chip Type: GeForce GTX 470
Display chip series: Nvidia GeForce GTX 470
Memory capacity (MB): 1280
Memory Interface (bit): 320
Core frequency (MHz): 607
Memory Type: GDDR5
Stream processing units: 448
RAMDAC: 400MHz
XFX GTX470 function parameters
3D API: DirectX 11
It seems 625MHz for GTX480, is a typo. It should be 700 MHz Graphics Clock
i dont think power consumption matters... nobody really cares...
what people care about is noise, heat and if they have to upgrade their psu...
if the card runs relatively quiet and not too hot and they dont need top u[pgrade their psu, i dont think anybody will care...
its hard to tell if those 50W extra fermi pulls vs rv870 is going to push most people to upgrade their psu... if anybody reallty cares, check the steam hw survey and check what psus are common and what cpus and gpus are common to get an idea of how much power headroom most highend systems have... i think the 50W extra wont be a problem psu wise...
about the different 480 specs, i think the 625mhz 480s are the 250W tdp cards and the 700mhz are probably oced editions with close to 300W... there is no mention of a 480 ultra with 512cores so far, or did i miss it? i cant find any mention of 512cores...
double gtx295 per4formance then?
you might argue that its gpu vs gpu, well then there should be a dual fermi card as well offering double the perf of a 295... but we all know thats not going to happen for what, 6 months? last i heard was late 2010 early 2011?
so then claiming double perf as their previous card is marketing bs...
i cant find the quote of somebody posting "so what, you claim fermi will be a 295 for the same price and same power, just with dx11, that cant be true after such a long time of waiting..." well, that IS pretty much what fermi is, isnt it? :D
im not saying its bad... like i said, except for 2560x1600 people there is no need for more powerful cards.
you call 31 and 37 average fps in a first person action shooter playable? :stick:
oh pleeeeease.... :rolleyes:
Yu Wei GTX470/480 army ready
Yu Wei GTX470 Specifications:
Integrated 448 stream processing units, the default core / Shader / memory frequency 607/1215/1674MHz, memory interface 320bit, capacity 1280MB-DDR5, bandwidth of 133.9GB/s.
Yu Wei GTX480 Specifications:
Integrated 480 stream processing units, the default Core / Shader / memory frequency 700/1401/1848MHz, memory interface 384bit, capacity 1536MB-DDR5, bandwidth of 177.4GB/s.
This is 700MHz LOL.
crysis being playable with 30 av fps... yes... but come on... if you could chose between 1920x1080 50fps and 2560x1600 30fps, dont tell me you would go for the higher res with 30 fps... :P
like i said before, imo going for a 30"screen is stupid if you wanna play games, cause its way expensive and you will depend on multi gpu for the next years and its just not as nice as single gpu, even with all the advancements...
oh and the nda ends mar 26 7:01 pm est
lol delays again??? :O
