turez what kind of air and how stable is that?
Printstable only.Quote:
Originally Posted by =[PULSAR]=
It's about 20-25c in my room.
I will try "outside-air" soon ;D
3GHz is not far away.
This one is sorta boring as far as memory bandwith goes, but a new record for me:-)
Fairly stable, so far... Windows, SuperPi 1million, 32sec a few times. I wanta go for 31s. Going to start increasing FSB a little. I think I might be ale to get 218x12.5, we'll see.
Winter-time rules!
http://img117.exs.cx/img117/3197/652700best.jpg
You memory is acctually running at 208MHz.
Please explain.Quote:
Originally Posted by craig588
A64 has this "bug" that rounds up every .5 multiplier. in other words:Quote:
Originally Posted by drcrawn
your REAL mem speed is (216x12.5) / 13 = 2700 / 13 ~ 208Mhz
Now with some TCCDs, but not 28sec. :mad:
http://people.freenet.de/funkflix/292dual.jpg
I'm still not following. I ran 216x 12.5 for 2700. That math seems right to me.Quote:
Originally Posted by bachus_anonym
Ok.. are you telling me that when I use .5 multis, the memory actually runs slower, even though all programs show it as 216mhz?
Seems like you are saying that 12.5 doesnt exist. Instead it is really 208x13, even though I chose a 12.5 multi. In other words, no such thing as a 1/2 mulit at all. Is this correct?
oh, i just didn't notice that you're running FX... that rule may not stick well to FX... but i'll double check that for you if REAL mem speed is showing up in CPU-Z mem tab...
@grave i thought the OCZ don't run very well??
Or did you have found the solution for it?
free
Dunno the solution for it, today i tooked them in again and it worked! :confused:Quote:
Originally Posted by freestylercs
Only 1.74v in bios and cooled with Mach 1 R507 :D
Totally stable in hours games playing, superPI32M, 3dmark but craps out in prime within 0.5sec. lol
http://www.xs4all.nl/~famchow/A64_34...I8M_3.1GHz.JPG
here's my GO at A64 S939 - 270x10=2700MHz @ 1.63v REAL, DDR540 6-2-2 cas2, OCZ DDR Booster 3.7v
MSI K8N Neo2 Platinum - Q47353.1 0440A2 S Taiwan
A64 3200+ 90nm "Winchester" - CBBFD 0441UPCW
Thermalright XP-90 w/ YTech 120mm
CLICK for Full Size Screenshot - 2048x1536 384KB
http://www.xtremesystems.org/forums/...chmentid=20513
This is max SuperPi 32M and 3dMark2001 stable.... 265x10 is my 24/7 usage so far :)
Hey bachus, after playing with multis and FSB all day yesterday, I think you are correct. Using a 1/2 multi really sucked. Even keeping the FSB around 217, a half multi just didnt perform well. My best performance comes with 12x and 220-222, if it doesnt crash in bechies. 2610 is about all I can get 24/7 stable with my cooling. Thanks for the info.
damn. I have the same exact 3200+ and it will only do 2.65ghz at 1.7vQuote:
Originally Posted by turez
My 3500+ on the other hand is doing 2.7ghz at 1.65v Stupid me can't find where I wrote down the cpu info though.
http://www.membres.lycos.fr/boblemag...cpumark330.png
3200+ CBBFD 0435 TPAW :(
Gigabyte K8ns ultra s939
2720mhz - 1.65v bios
Aircooling box
Max Benchs
2*256 A-data BH5 (2/2/2/2/7/11) 3.75v
my result...on Watercooling...
n.. .
Me very jealous ;) Whats your max stable clock say 32M for SPI?
cpuz stable :D :p: :)
you guys are impressive! I'm using an early made winchester and OCZ 3200 Plat. These rams doesn't allow me to try higher HTT with 1:1. My best try is 218MHz 2-3-5-2 1T :( Hope 3200 Plat rev.2 could do better
A little better. Still air cooled
ADA3400AEP4AX
CBAZC 0435XPMW
1094922140518
1.7 volts
Corsair was set to 333 and timings were loosened to 2.5-3-3-7...killed my SuperPI.
i see a lot of 2.9ghz with winchester 3200+ ... i got 2934mhz with 3000+ ;):P
http://www.geocities.com/kl00tzakje/2934.JPG
it even booted @ 2943 mhz but after being 10 seconds in windows, my hard disk had a struggle :(
i Had 3 x 3200+ 0441 and best one went through superpi8m around 2550Mhz 1,65v i had very bad luck :stick:Quote:
Originally Posted by klootzakje
