thank you... do you remember something about the vmem incresing?
i've founded this in old pages, but the user wasn't sure:
http://www.postimage.org/aV12hJDS.jpg
and what about the vmem measure points?
I didn't care about VMEM, so I can't say much about it.
thanks anyhow. :)
does someone else know something about the vmem mod on the sapphire dual slot?
Hey, can anyone please help me out and tell me the value of the circled component, which is what I beleive is a capacitor? I was taking off my RAMsinks and while cleaning accidentally pulled it off and lost it. :down:
HIS Hightech HD 4850, the actual card is green in colour but the layout is the same. It is under C635 the second component up from the large capacitor.
Thanks alot!
Alexey
do you mean those two ? and do we know witch one is the Mvddc and witch is the Mvddq ?
i have one of those and i'am going to mod the Vgpu but i want the Mvddc and the Mvddq as someone said MVDDQ can provide more oc headroom
Attachment 96230
ΟΚ 10κ Vr is not working on the sapphire it dose not adjust the voltage at all :(
and yes it is soldered correct on the card it gave the card a small bump on the voltage from 1.32V it went 1.36 but thats all not more
how many Ωhms do you measure from the soldering spot to the ground ? are you sure it 10k your vr ? as i measure we need a ~500k vr not a 10k
EDIT
500k Vr did the job fine :p
YIKES! That was suppose to be 100K not 10K. I've changed the caption for the correct value. Thanks for actually questioning it :up:
Your 500K may actually work better if you ever need to get back to stock volts. I chose 100K because it gives me finer control with my shaky hands :D
:p: no prob mate but i still cant understand something :p even with the 500k vr my card cant raise the voltages the 500k vr raises it about 0.5 and then it stops :p: i might have done the mod wrong i wll check it out again :)
pff done it :)
http://img10.imageshack.us/img10/400...e4870vmodm.jpg
Any chance one of you could clock match the 4890 (850/900) and do a couple of benchmarks vs stock 4870?
Great job finding the pin-out diagram :bows: Looks like my original "shot in the dark" mod was a bit off the mark...it's working much better now :D
I've updated my orignal post with your new info and all due credit :up:
BTW, what clocks are you running with 1.4v? I can only get up to 880mhz Furmark stable.
Hello!
I'm buying Radeon 4830 next week. I know that every 4830 has the same PCB as 4850. I'm wondering whitch of the cheapest referent cards are the best to do pencil mod (if there's any...): Gainward, Sapphire or maybe Powercolor??? I'd prefer Gainward because of its warranty in my country. My primary object is that I could be able to do pencil mod of that specific card.
Gainward would probably look like this one:
http://sklep.e-skarzysko.pl/media/ca...e8615d50d6.jpg
Sapphire:
http://img.hexus.net/v2/news/sapphir...4830-4-big.jpg
Powercolor:
http://nvision.pl/img/200810/powerco...hd_4830_02.jpg
I'll change stock cooler with Accelero s1 plus 120 mm fans.
So what are your opinions?
Thanks in advance :)
Thanks, looks like 850MHz does not give a 20% gain over the 4870
pff so it's my bad luck :p
with 1.5 i cant pass 880Mhz :( and i think the mosfets are getting so hot that the card return artifacts
can you post a picture on how you cool the card plz :) ?
It's just a MCW-55 GPU block and a 92mm fan blowing down on the card:
http://img243.imageshack.us/img243/3396/4870vmod012.jpg
damn same thing here but the card wont clock good :(
Hello,
can anyone please help me with the OCP and OVP Mod for my Powercolor 4870 pcs+ rev2.
The card have a NCP5388 Voltage Regulator. http://www.onsemi.com/pub_link/Collateral/NCP5388-D.PDF
Vmod is 200K Trimmer from Pin19 to VR.
http://www.abload.de/thumb/ncp5388_1zqfs.jpg http://www.abload.de/thumb/ncp5388_2bbt8.jpg http://www.abload.de/thumb/06_18121f4mp.jpg
I flasht the card to 950Mhz Core and take 1420mV for a short Test with LN2. Itīs work wonderful since the firts moment. But when i turned up to 1460mV the System crashed under load and the output Voltage goes down to ca. 200mV.
in the Data sheet Page 25 and 33
But if the OVP is not adjustable and works only at soft−start, the reason can be by OCP?Code:OVP
The overvoltage protection threshold is not adjustable.
OVP protection is enabled as soon as soft−start begins and
is disabled when the part is disabled...
The OCP works via a resistor divider between Pin12 and Pin13. Page 7 and Page 25
Can i pencil the marked resistor to disable the OCP?
Thanks.
Seb
Ps: sorry, its not the best english
Hello, I finally managed to take a nice close up pic:-
http://img6.imageshack.us/img6/6862/...2hd4850.th.jpg
Can you help me in volt modding my vGPU now?
lycanwrath,
You have been PM'ed.
does this mod apply to the 4830 aswell?? its the same board as the reference 4850 board, so maybe its the same mod ?? Please answer :D
If the board is physically the same then it works, yes.
