I might end up getting it and trying. Just to feel a little safer, I might end up using this Artic Adhesive to fully secure it.
What do you think?
What do you think?
If you want a fan this looks even better.
http://www.enzotechnology.com/slf_1.htm
As you say with WC cards I am OK with passive. Will try the Evercool tomotrrow.
This one?
Is it big enough to cover the middle (main) part of the SB?
Hi,
anyone a Idea how can i bring up my CPU up to 4.5 GHz +
(CPU and NB was Watercooled with Mora Pro 2 and 2 Fan Radiator)
at the moment it runs at 4.3 GHZ with Multi 13
and
Vcore 1.42V
VTT 1.16V
PLL Auto
GTL 1+4 +28mv
GTL 2+3 + 26mv
NB 1.46V
thx and sy for bad english
God how come I didnt notice this!
But just one question, on the first picture it looks like its really tall. Tall enough to make the middle slot useless for Tri-SLI.
How did you make your middle card fit?
Also, is that heatsink good? what are your temps for SB? Is it crooked or angled?
[QUOTE=slim142;3145523]Im tellin you, I dont think there is anybody here able to run 1T. You wont get a huge drop when using 2T, but you gain a lot more stability. Give 1600Mhz 2T a try.
??? I've been running 1T the whole time, I never crash or have any problems.
Computer runs 110% :up::up::up:
Hello there,
Can anybody tell me best bios i am on 704 at the Mo and still getting the old random game crashes:mad:
spec Q6600 @ 3.74
reaper ram at 1150
2x8800gtx
The overclock is 12 hours prime stable nice temps just random freezing in games not system crashes:shrug:
Cheers
Slim, if you need further convincing about the evercool, see mine below:
http://img297.imageshack.us/img297/6...edresiznp3.jpg
Fits fine, and should have clearance from cards - ive used it in SLI setups before and height isnt an issue. The only thing to be aware of is the lug/catch on the white PCI-E slot gets in the way a bit, but u can bend it out the way a little and that sorts it. :)
I tried 1.92v, and I don't see any improvement.... it is already 0.12v above the safety limit and I don't want to go any further.
And it is completely stable at 4037 MHz / 1700 MHz, 10 hours of 3DMark06 + Orthos + Bittorrent and still going. VCore can be reduced to 1.33v too, temp looks much better.
There were some false alarm though, Crysis has antifact and random crash, it turned out to be due to Beta Forceware driver 177.40 and 177.66. Back to WHQL 175.19 and all is well.
I don't know why, seem you guys these Beta driver to solve the SLI issue, even at stock. I don't have those issue, instead it was these beta driver which give me issue.... not only in Crysis, but general performance is bad also.
For Justfire
Heya man, just wondering if you wouldn't mind posting your BIOS specs for your setup. Still tryin' to hit 4ghz+ stable..getting ever so close but it seems this bad boy needs lots of voltage.
Cheers :cool:
P.S. By all means if anyone else with a QX9650 wants to post some 4ghz+ specs, have at it. :D
Perhaps you and I need to meet up for more than PC things ;)
My ride :D
http://i89.photobucket.com/albums/k2...O/DSC00037.jpg
I am also thinking of going down the water cooling route, so all this info is helping me out.
