i've got a 120mm fan on the case side panel blowing over the mobo and NB, when i bench and do linx/prime/game i crank up the fan speeds so theres quite a bit of air flowing onto the NB - i'll try 1.4v. safe for 24/7?
Hi all, I'm thinking about buying a GA-EP45-UD3P.
(I have a Q9650 no o/c, I'm going to start with my X38ds5 but it's going to suxx I think...)
Anyway, I would like to know if there is a better rev on this motherboard ? (rev1 to 1.6)
Honestly rev 1.0 was the best but, you could buy an ep45T-usb3p do 530fsb on ddr3 ram. Giving you better bandwidth.
Hey guys, possibly found a great Q9650.
Batch # L828A446 and VID 1.1375. Seller said he got it to 4.2 at 1.25 on water.
Guys im thinking about selling my q9650 and am curious what you think these chips are worth nowadays.
Quick PK1 application and first boot with new Q9650. Bios Voltage - 1.4V, Termination 1.36V. Runs super hot even under my HD-D14 with two 150cfm Deltas :eek:
Batch # L828A446 - same as andressergio and nkreshno Q9650, I believe.
http://i465.photobucket.com/albums/r...g?t=1297223928
Finally got 4.5Ghz with 8Gb of Tridents chugging away @ 1200Mhz. Can run Prime 95 blend (128k - 4048k fft) all day with 6.8Gb of ram but small fft keeps freezing up on me. Amazing chip, only need 1.4V BIOS for 4.5Ghz so far.
I am thinking I should push CCPU Clock Drive to 900mv in ACC, because currently its 800mv.
My settings:
Code:*******************************************************
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: Auto
CPU Clock Ratio ......................: 9x
CPU Frequency ........................: 4.50GHz (500x9)
************** Clock Chip Control **************
>>>>>> Standard Clock Control
CPU Host Clock Control................: Enabled
CPU Host Frequency (Mhz) .............: 500
PCI Express Frequency (Mhz) ..........: 100
C.I.A.2 ..............................: Disabled
>>>>>> Advanced Clock Control.........: [Press Enter]
CPU Clock Drive.......................: 800 mV
PCI Express Clock Drive...............: 800 mV
CPU Clock Skew (ps)...................: 0ps
MCH Clock Skew (ps)...................: 50ps
*********** DRAM Performance Control ***********
Performance Enhance...................: Turbo
(G)MCH Frequency Latch................: Auto
System Memory Multiplier .............: 2.40B
Memory Frequency (Mhz) ...............: 1200
DRAM Timing Selectable ...............: Manual
>>>>>> Standard Timing Control
CAS Latency Time......................: 5
tRCD .................................: 5
tRP...................................: 5
tRAS..................................: 15
>>>>>> Advanced Timing Control........: [Press Enter]
tRRD..................................: Auto
tWTR..................................: Auto
tWR...................................: Auto
tRFC..................................: 68
tRTP..................................: Auto
Command Rate (CMD) ...................:Auto
>>>>>> Channel A Timing Settings......: [Press Enter]
Static tRead Value....................: 8
tRD Phase0 Adjustment.................:Auto
tRD Phase1 Adjustment.................:Auto
tRD Phase2 Adjustment ................: Auto
tRD Phase3 Adjustment.................: Auto
Trd2rd(Different Rank)................: Auto
Twr2wr(Different Rank)................: Auto
Twr2rd(Different Rank)................: Auto
Trd2wr(Same/Diff Rank)................: Auto
Dimm1 Clock Skew Control (ps).........: Auto
Dimm2 Clock Skew Control (ps).........: Auto
DDR Write Training....................: Auto
>>>>>> Channel A Driving Settings.....: [Press Enter]
Driving Strength Profile..............: OC 1200
Data Driving Pull-Up Level............: Auto
Cmd Driving Pull-Up level.............: Auto
Ctrl Driving Pull-Up Level............: Auto
Clk Driving Pull-Up Level.............: Auto
Data Driving Pull-Down Level..........: Auto
Cmd Driving Pull-Down level...........: Auto
Ctrl Driving Pull-Down Level..........: Auto
Clk Driving Pull-Down Level...........: Auto
>>>>>> Channel B Timing Settings......: [Press Enter]
tRD Phase0 Adjustment.................: Auto
tRD Phase1 Adjustment.................: Auto
>>>>>> Channel B Driving Settings.....: [Press Enter]
********* Motherboard Voltage Control *********
Voltage Types...........Normal..........Current
>>>>>> CPU
Load-Line Calibration.................: Disabled
CPU Vcore..............1.31250v.......: 1.40V
CPU Termination........1.200v.........: 1.32V
CPU PLL................1.500v.........: 1.57V
CPU Reference..........0.780v.........: 0.836
>>>>>> MCH/ICH
MCH Core...............1.100v.........: 1.440V
MCH Reference..........0.800v.........: 0.928
MCH/DRAM Ref...........0.900v.........: Normal
ICH I/O................1.500v.........: Normal
ICH Core...............1.100v.........: Normal
>>>>>> DRAM
DRAM Voltage...........1.800v.........: 2.0400V
DRAM Termination.......0.900v.........: Normal
Channel A Reference....0.900v.........: Normal
Channel B Reference....0.900v.........: Normal
You might want to raise your vtt up a notch, the 1.32 vtt setting doesnt work right its really the same voltage as the 1.30 setting.
Sorta yea, the voltages 1.30 and lower generally have a slight overvolt and 1.34+ start undervolting some. 1.30 is really like 1.31 and 1.34 is like 1.33. And as for the drive strengths I never saw them make a difference in stability so I kept them at default 800/900, unless benching.
L827a945 1.15
Nearing on total 4.5Ghz stability on air. ACC does help a little bit, at least from my experience with my older Q9650, 800 > 900mv was equivalent of bumping vcore one notch.
ACC : 900/800/0/50
Cpu Vcore : 1.3975V
Cpu Term : 1.34
PLL : 1.57
Term Ref. : 0.836
Mch Core : 1.44
Mch Ref. : 0.916
Dram Voltage : 2.06
http://i465.photobucket.com/albums/r...0Mb_Stable.jpg
That's a lovely low vcore for that speed - nice chip! You gonna bench it or at least try for higher fsb?
CPU-Z 5GHz
Cinebench R11
Q9650@4950MHz 6.04pts
http://img141.imageshack.us/img141/3838/cine550.th.jpg
Good clock oldcomer! I'm tempted to have another stab with my old Q9650 - snag is I only have the USB3P to run it on. I'm sure it'll be great for benching pi32m but don't know if this board can push as well as my UD3P rev1.6 (which now has another home). I guess trying won't harm it although it'll be on air (with lots of big fans) if I do. I think I need a pot and some LN2, but sounds too expensive for what it's worth....
Only had it for a week so far but definitely going to push it to the limit. Once I get water, say 4.8Ghz 24/7 stable :D
Got 4.5Ghz Blend stable ( 8k - 4096k fft, 6200mb). Ambient temps were a bit higher then usual because of the really warm weather here. Thanks to Jorbl3r and his Q9650 4.5Ghz settings, I was having some issue with large fft stability, plugged in his numbers for Mch Core and Mch Ref and bam..no problem.
ACC : 900/800/0/50
Cpu Vcore : 1.3975V
Cpu Term : 1.34
PLL : 1.57
Term Ref. : 0.873
Mch Core : 1.42
Mch Ref. : 0.888
Dram Voltage : 2.06
Trying to push the chip to 4.55 but I keep getting restart / freeze issues. Should I increase MCH Clock Skew to 100ps from 50ps?
Try upping the cpu skew 50ps, that was what solved that problem for me at those speeds.
L036B363 (no hits on Google!)
VID 1.2625 (CoreTemp)
Chip must have 1.31 to be P95 (small FFT) 4G stable.
Probably limited by my MB (P35)
can someone help me get my q9650 stable @ 3.8ghz??
My mobo is an asus x38 ddr3 maximus extreme! I run my cpu 24/7 @ 3.6ghz 400x9 with NB temp at 32C idle but 3.8ghz makes my NB hot reaches 50C (altough cooled with an antec spot cool)
to get the mobo stable at 3.8ghz i have to pump 1.7+volts to my NB less than that it is unstable in gaming. FSB VTT is at 1.4v, CPU PPL 1.6v, CPU core 1.3v and Loadline Calibartion enabled is a must to eliminate vdroop!!
I use the corsair h70 with push/pull stock fans to cool my cpu :) As for the TIM i use the AC MX4!
My Q9650 Retail box!
http://i54.tinypic.com/20u3ddk.jpg
My Current OC @ 3.6GHZ - 2hrs Prime95 stable, OCCT 1hr stable
http://i53.tinypic.com/fk8vtj.jpg
Your v core is way too low, and if you have the north bridge any higher than 1.58 you risk motherboard damage, your pll is not proper either I think I used 1.65 sometimes more, try also please list what timings your using on the ram, and just to be honest you should be using a q9650 on a p45 board to get its full potential out. I hope some of my input help as I've seen the worst of the batches do better than what you've provided you'll need to increase your v core to 1.42 if it works from there lower the v core by two or three intervals until it isn't stable.
so you mean i need to set vcore to 1.42 for 3.8GHZ? isn`t cpu pll 1.65v too much for 45nm cpu? as for my northbridge it needs 1.7volts less than this it is unstable! My ddr3 ram is corsair DHX 1600mhz 9-9-9-24 stock timings 1.8v
Here are my current BIOS settings on my asus maximux extreme mobo..bios is v1302
3.8GHZ 430x9 Overclock settings
CPU Ratio Setting 9
FSB Frequency 430
FSB Strap to North Bridge Auto
PCIE Frequency 100
DRAM Timing Control Manual
DRAM Frequency DDR3-1720
DRAM Command Rate 1T
CAS# Latency 7
RAS# to CAS# Delay 7
RAS# Precharge 7
RAS# Active Time 20
RAS# to RAS# Delay Auto
Row Refresh Cycle Time Auto
Write Recovery Time Auto
Read to Precharge Time Auto
Read To Write Delay(S/D) Auto
Write to Read Delay(S) Auto
Write to Read Delay(D) Auto
Read To Read Delay(S) Auto
Read To Read Delay(D) Auto
Write To Write Delay(S) Auto
Write To Write Delay(D) Auto
DRAM Static Read Control Disabled
DRAM Dynamic Write Control Disabled
Ai Clock Twister Strong
Ai Clock Skew for Channel A Auto
Ai Clock Skew for Channel B Auto
Ai Transaction Booster Enabled
Boost Level 3
CPU Voltage 1.325 Actual reading > 1.304
CPU PLL Voltage 1.6 Actual reading > 1.664
North Bridge Voltage 1.8 Actual Reading > 1.792
DRAM Voltage 2.0 Actual Reading > 2.032
FSB Termination Voltage 1.4 Actual Reading > 1.312
South Bridge Voltage 1.1 Actual Reading > 1.104
Loadline Calibration Enabled
CPU GTL Reference 0.63x
North Bridge GTL Reference 0.67x
DDR3 Channel A REF Voltage Auto
DDR3 Channel B REF Voltage Auto
DDR3 Controller REF Voltage Auto
SB 1.5 Voltage Auto
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
UPDATED!
Something you should know 2.0 vdram is considered suicide on air , secondly you should consider I have stabilized many systems and set fires to enough systems to know what's safe and what's damaging. Your northbridge/mch is too high I don't even use that much for liquid nitrogen. Secondly you must read this whole section pages 1 to the end or don't bother overlooking unless you have the money to throw around or you could damage everything you have with the voltages your using....
Wanted to add something else yorkfield based chips can die to termination being 1.38 or higher your playing in danger atm..
well 2.0v on this ram is ok according to corsair (ramguy) but 2.1v is the absolute maximum! as for my x38 chipset it is well known that it needs juice to stay stable and i saw people running this mobo on 1.7v red zone volts in the bios and according to intel spec this chipset temp limit is 90C and i never reached that much temp. the most i reach is 50c (cooled with antec spot cool) with with 1.7v when you say you dont even use that much voltage for LN i dont beleive you sorry remember x38 get hot soon and needs volts at high fsb :)
You could very well be right since its x38 and all of us with q9650 or the extreme version used p45 ud3p motherboards to achieve great clocks. But honestly you really should go to p 45 if your having trouble with 425 fsb or greater . My qx9650 which I sold for its full retail cost because of what it could do, used ud3p mobo and could do 530 fsb with low termination and low volts ran very cool :) maybe you should consider it.
Well i jumped on the bandwagon and my batch is L037B486 with VID 1.30000.
I clocked it stable on 4050MHz, 60 degrees on load, cooling is a lapped TRUE 120.
Gonna go for 42xxish for 24/7 and than i'm a happy boy!!!
edit: nope, my ram is the limiting factor, on 460 it crashed and it isn't the power, i even tried 2.0Volt on my RAM and no difference. So now it is 4050MHz, well it does 57Gflops in IBT on 4050MHz, i see people with 4200MHz and they have 58Gflops.
I bought a second hand gigabyte ga-ep45t-ud3p p45 ddr3 mobo from ebay and it`s on it`s way to me! I will be using a pair of 2x2gb corsair xms3 dhx ddr3 1600 9-9-9-24 1.8v stock timings on the board. anyone knows if my ram will be good for overclocking with my q9650 on the ga-ep45t-ud3p? i did not opted for the ga-ep45-ud3p cause it is ddr2 and i have ddr3 ram atm. Is it true that the ga-ep45t-ud3p is picky on ddr3 ram?
Only way to find out is to try it out, is it a new Q9650 like mine, i bought mine couple of weeks ago, production date end 2010 with a high VID, i can't get mine over 4200MHz, i even bought new ram (dominator GT 2000MHz).
My proc needs in bios 1.49Volt but temps are not extreme, in IBT on 100% load it rises up to 67 degrees celsius.
my q9650 pack date is: 5/3/2010 with 1.2250 vid batch # L009B453 and bought it 9months ago
Yeah but i guess i'm done clocking on this one, 4200 is enough for gaming and ingame it gets 55-58 degrees max (temps are different cores) and i won't gain nothing much extra for going higher as in 4300 or 4400 for 24/7.
My next PC will get his ass kicked and will run like a b***h for 24/7, going for watercooling i guess.
socket 775..so dated..:shrug:..................i7 ftw.
Call of Duty: Black Ops GPU & CPU Performance In-depth
"Black Ops on the other hand saw a massive 78% increase in performance when clocking our Core i7 processor from 2.0GHz up to 4.0GHz, and we continued to see a performance increase right up to the maximum tested frequency. Both the minimum and average frame rates were affected, suggesting that users who are in need of better performance will want to overclock their processor for this game."
http://www.techspot.com/review/336-c...nce/page7.html
Thinking about selling mine. It's J0r3lbr's old chip.
Send it to me.
I'll take good care of him :yepp:
Hey guys, I could use some good old X48 advice. My CPU is a QX9770. I just installed 8GB of Corsair RAM (1600C8). My motherboard is the P5E3 Premium. As you may know, this board is quite picky with regard to settings. Currently the RAM is running at 1280MHz, however, it is rated to 1600MHz. FSB is 400 (default for this CPU) and CPU multiplier is 9.0 giving 3.6 GHz. I have been trying to increase the memory speed by upping the FSB. I have backed off on the CPU multiplier when the FSB has been increased. LinX is stable, and SuperPi is stable. However, at even FSB 420, I run into errors in Prime 95 at about 7-8 minutes. I have tried increasing the CPU voltage as well as the NB voltage to no avail. It continues to act exactly the same each time when the FSB is increased. What would you recommend that I change in order to get things more stable? It seems like it shouldn't be all that hard to overcome this, but I'm at a loss here. Thanks in advance.
While benching for the CountryCup 2012, I've managed to set a new record so it's time to bring up this old thread.
http://img213.imageshack.us/img213/4...perxptrefo.jpg
http://static.hwbot.org/images/cup-gold.png Q9650@4995MHz SuperPi 32m 9min 18sec 766ms
Damn nice work!
I miss my golden Q9650 :(
I'm back to testing my Q9650 while I'm moving to an Ivy Rig and it appears that the vcore selected in bios does not match the actual voltage supplied to the chip.
I'm monitoring power consumption through everest and now my computer shuts down at 235 Watts instead of its usual 210-215 W max in the past. Only reason I can think of is the mobo is no longer delivering as much voltage as shown in cpuz / selected in bios.
q9650 @ 4.5 GH v 1.425
http://i49.tinypic.com/sxna78.jpg
Q 9650 @ 4.6 GH
http://i45.tinypic.com/w7j5gz.jpg
http://i45.tinypic.com/2i6m068.jpg
^that is an awesome chip Gaul, what kind of cooling?
thx, CORSAIR H100 with 4 FAN
MAX CLOCK with safety volt 1.456 ( i quess )
http://i48.tinypic.com/o9e9ec.jpg
You guy shave done a LOT with this chip since i last checked things out. I've been running at 4.05GHz on a COrsair hydro since I last touched my bios with i think was 2011!.
I decided my last effort was going to be trying to take advantage of the memory clock abilities now that memory nativley hits 2400. So I picked up some Viper pc3-19200 (pv38g240c1k) 2400MHz 11-13-13-31 but i'm having some trouble getting it to run at anything beyond the last clock I had my slower kensington hyperx running at. here's my config. Hoping someone might be able to help me get this figured out.
Code:GIGABYTE GA-EP45T_USB3P
[u]MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: FAST
CPU Clock Ratio ..........................: 9X
Fine CPU Clock Ratio.....................:0.0
CPU Frequency ...........................: 4.05GHz GHz
Clock Chip Control
CPU Host Clock Control..................: [Enabled] []
CPU Host Frequency (Mhz) ............:450Mhz
PCI Express Frequency (Mhz) .........:100Mhz
C.I.A. 2.............................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................:800 mv
PCI Express Clock Drive...................: 900mv
CPU Clock Skew (ps).......................: 0ps
MCH Clock Skew (ps).......................: 0ps
Performance Enhance....................: [TURBO]
Extreme Memory Profile (X.M.P.)........: disabled
(G)MCH Frequency Latch.................: [400]
System Memory Multiplier ..............:3.33D
Memory Frequency (Mhz) ..............: 1500Mhz
DRAM Timing Selectable ................: [Manual] []
CAS Latency Time...............................: 8
tRCD ..........................................: 8
tRP...........................................: 8
tRAS...........................................: 24
Advanced Timing Control [Press Enter]
tRRD...........................................:AUTO
tWTR...........................................: AUTO
tWR............................................: AUTO
tRFC...........................................: AUTO
tRTP...........................................: AUTO
Command Rate (CMD) ............................: AUTO
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value......................:Auto
tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)..................:Auto
Twr2wr(Different Rank)..................:Auto
Twr2rd(Different Rank)..................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control................:Auto ps
Dimm2 Clock Skew Control................:Auto ps
Channel A Driving Settings [Press Enter]
Driving Strength Profile:[AUTO]
Data Driving Pull-Up Level.............:Auto
Cmd Driving Pull-Up Level..............:Auto
Ctrl Driving Pull-Up Level.............:Auto
Clk Driving Pull-Up Level..............:Auto
Data Driving Pull-Down Level...........:Auto
Cmd Driving Pull-Down Level............:Auto
Ctrl Driving Pull-Down Level...........:Auto
Clk Driving Pull-Down Level............:Auto
Channel B
Channel B Timings Settings [Press Enter]
tRD Phase0 Adjustmen...................:Auto
Channel B Driving Settings [Press Enter]
{U]Motherboard Voltage Control{/U]
Load Line Callibration.........................:Enabled
CPU Vcore….???...........................:1.29375v
CPU Termination…...... 1.200V*...........: 1.260
CPU PLL…??????.........1.500V*...........: 1.5000v
MCH/ICH
CPU Reference.??????.........1.500V*...........: 0.823
MCH Core…????..........1.100V............: AUTO
MCH Reference..…...?.?.0.800V............; AUTO
ICH I/O…???....??......1.550V............: AUTO
DRAM
DRAM Voltage …?........1.500V............: AUTO
DRAM Termination ...…..0.900V............: AUTO
Channel A Data Vref ...0.75V.............: AUTO
Channel B Data Vref ...0.750V............: AUTO
Channel A Address Vref 0.75V.............: AUTO
Channel B Address Vref 0.750V............: AUTO
[b]{U]Advanced Settings[b]{U]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
Note: * refers to 45nm CPU
