CPUID: 20F71
APICID: 0
Revision: SH8-E4
Precessor: AMD Opteron 146 (San Diego)
Speed: 2650 (265 x 10)
Platform: Socket 939
MaxTCase: 55C
VCore: 1.400V
CPUID: 20F71
APICID: 0
Revision: SH8-E4
MaxTCase: 55C
VCore: 1.400V
CPU Information (CPU #1):
Standard CPUID: Family: F, Model: 7, Stepping: 1
Extended CPUID: Family: F, Model: 27, Stepping: 1
CPUID String: 20F71
Processor APIC: 0
Processor: AMD Opteron 148 (San Diego)
CPU Speed: 2860.20 (260.02 x 11.0)
Revision: SH8-E4
Startup VCore: 1.400v
Maximum Case Temperature = 57C
very nice!Quote:
Originally Posted by NYCTeeN82
here's my 146:
CPUID String: 20F71
Processor APIC: 0
Processor: AMD Opteron 146 (San Diego)
CPU Speed: 2900.08 (290.01 x 10.0)
Revision: SH8-E4
Maximum Case Temperature = 63C
oops, seems that i'm at 2.9ghz :confused: :D
CPUID String: 20F71
Processor APIC: 0
CPU Speed: 2210.19 (200.93 x 11.0)
Revision: SH8-E4
Maximum Case Temperature = 65C
CPUID String: 20F71
Processor APIC: 0
CPU Speed: 3300.84 (300.08 x 11.0)
Revision: SH8-E4
Originally Posted by el rolio
Prime, or super pi...similar mathematical error...all stems from the same thing => instability. Ok buddy?
Superpi more tests the Ram than the CPU!
CPUID String: 20F71
Processor APIC: 0
CPU Speed: 2800.00 (280.00 x 10.0)
Revision: SH8-E4
Maximum Case Temperature = 67C
Just got my 148 in today from ewiz. CABNE :woot:
First attempt. Have to run 2T because of running 4x512.
Time to update my sig......This one's a keeper. :fact: :toast:
Well, why pi at 3ghz was fairly easy...getting more than an hour at prime is proving to be extremely difficult. Don't want to bring up the whole pi/prime debate but I am kinda uncomfortable having my computer write files when its math is .1 off.
OPTERON 148 CABYE 0536 GPMW
Running 1.5v @ 2.85GHz on quiet air Prime Stable 12+ hours; anything over 260FSB fails prime even at 1.65v and with Mem on a divider, maybe my neo2 plat ?
CPUID String: 20F71
Processor APIC: 0
CPU Speed: 2849.16 (259.01 x 11.0)
Revision: SH8-E4
Maximum Case Temperature = 59C
u guys should post these maxtcase values in the thread dedicated for this
Originally Posted by foofreaknfighte
Lighten up bro. :rolleyes: I posted a quick screenie like 5 minutes after I popped it in my board. Just wanted to share some quick info. :)
I really, really agree. :( Suddenly this thread has turned into a "what's your MaxTcase" instead of an oc thread. I really don't think a higher mtc means higher oc but if that makes your wheel turn, fine. :) Even if it does, you can't find out what it is until you buy the cpu and test it. It's not like a stepping you can hunt for. Or, even a T or N on the cpu that may or may not have anything to do with oc'ing the cpu.Quote:
Originally Posted by dinos22
Please try to stay on topic :off: and let's see some more tweaker ss in with the rest of your oc. Also, lets not :horse: over "you didn't prime enough". I thought this was XS.
Then by all means you need to have your computer prime stable. I am fine at 32m or OCCT stable. I am not trying to make you uncomfortable by saying you should just be doing 32m or OCCT, please don't make me uncomfortable by saying I should do prime.Quote:
more importantly post the cpu's idle/load temp and ambient room/case temps you have to achieve the clocks :)Quote:
no way, the another thread its for a64... :DQuote:
heheheh let's invade the A64 thread hehehQuote:
Originally Posted by periquitos
it's easy......as eva2000 said above..............do the OCs....idle load and you can include a screenie of maxtcase as well in there.....that way it's probably more informative anyways
has anybody ordered from monarch? they have OEM 146's in stock, i want to jump on it, but a cabge would be a side-grade for me.
I think that they posted that they were instock to just hype things up a little and get orders in could be for real though but dont give your hopes up
ok fellows, this is where im at. sorry i dont have photoshop installed. i will try and come back to it. maybe i can up the voltage a bit, tho it was superpi that threw the error, leading me to believe it was the memory givng me issues
and here is the cpuz validation http://valid.x86-secret.com/show_oc?id=44676
http://img478.imageshack.us/img478/1...reen2zt.th.jpg
the ambient temp as read by speedfan on the 6800 is 29 degrees.
basically i hit that wall at 280 last night, wass given a hot tip that maybe my ram can do a certain speed, my cpu can do a certain speed but the memcontroller cant allow both. so now im runnin ram closer to stock... but it seems there is tweaking to be done as i can do 1m, 2m, 4m, 8m, but not 16 yet stable in super pi.
oh and the concept is, if this is how its gonna be, i might as well put the bh-5 golds back in.
all in all tho, side effect and ozzimark really helped out, thanks guys.
aiit folks, got the 32m prime stable. upped ram voltage to 2.75v and also tried a diff combi of VID and % to get where im at of about 1.55 avg.... gosh i hate neo2 fluctuating vcore.
http://img478.imageshack.us/img478/7...reen5pv.th.jpg
as it stands now im done for tonight. gonna start a prime blend test? i guues thats the best to do and let it run till morn. should be a good 7 hours and hopefully it runs thru the night. *wish me luck!
im pretty sure im pumpin a tad bit more volts than is actually necessary to be stable but its just in an effort to compensate for the wildy fluctuating voltage courtesy of the neo2. *sigh.
What bios are you guys using for the 2GB Ballistix? can you please post the Tref value, Dram drive and data strength?
Then start your own thread just for MaxTcase. There is no sense of trashing up an oc thread with that. Someone who just gets an opty or is new to the forum and wants to find out about how the opty's oc shouldn't have to go thru a lot of MT posts to find oc info. This tread has pasted up the venice, sd and x2 threads is a short time. Please don't trash it up.Quote:
periquitos, your new here, please respect other people threads. If MT is that important to you, start your own thread. Don't hijack. :nono:
I have got the same stepping here:Quote:
Originally Posted by Whap
148 0536GPMW 0189er Batch
(not so nice as my 144, but really 3GHz)
http://mitglied.lycos.de/freestylerc...2V%20prime.JPG
free
