Hey Ket I have a question about RAM OC.
I'm still a noob about OC RAM. I want you to take a look at my settings.
Thanks a lot in advance!!
When I had 4.6Ghz (1.315v), I could make my RAM to go 1866 9-9-8-24 1T 1.545v, VTT@1.051
Now I'm at 4.8GHz (1.384v), I needed my RAM to be 1866 9-10-9-28 1T 1.650v, VTT@ 1.077
Also this MB and RAM don't like lowering CPU PLL Voltage at high clock.... so I'm at default 1.832...
Both stable with HCI memtest and LinX Max run. But does this look right to you?
I'm surprised that I needed a big jump in terms of DRAM voltage.... (anything less than 1.65 will give me unstability, errors in memtest)
Also I've been messing around with VTT(VCCIO) and I found out that 1.077 is the sweep spot.
Anything lower will make my RAM unstable, anything higher will give me a bit lower GFlops in LinX and also more heat.
I get healthy GFlops gain in LinX (130+GFlops) but going from 4.6 to 4.8 makes this much difference in terms of the settings goes...
I know I have a 2x4G so it is making the IMC stress harder than 2x2G sets. Even I'm getting healthy GFlops and stable, Is the settings look OK to you?
I might can make the timings a tad better but as far as voltage goes, I got it stable with as less voltage as I can make it I think... Unless I'm doing something wrong...
http://preview.filesonic.com/img/31/....thumbnail.jpg
