Nice bench table! And new appogee hd ... mmm yammme :)
new cpu round up coming ?
Love the Alphacool DDC-silent box.
Does the box dissipate any heat? Would you say the pump runs hot in the box?
There is a review at hardwaremax.net about the silentbox
http://www.abload.de/img/img_45321kxeo.jpg
http://www.abload.de/img/img_4538gszsu.jpg
http://www.abload.de/img/img_4544syanh.jpg
http://www.abload.de/img/img_4542nqxyh.jpg
http://www.abload.de/img/img_4547xe3mp.jpg
pretty cool fittings....
Are they some form of compression?
-PB
Asus Mars GTX 295 with Bitspower cooler.
http://www.abload.de/img/45xzwq.jpg
http://www.abload.de/img/4q9aa8.jpg
http://www.abload.de/img/5wax8b.jpg
http://www.abload.de/img/4lty0g.jpg
Jelly!
-PB
http://www.abload.de/img/img_7068ih1k59.jpg
http://www.abload.de/img/img_7007frjx9.jpg
http://www.abload.de/img/img_7030jcj6t.jpg
http://www.abload.de/img/img_6945w6jki.jpg
http://www.abload.de/img/img_6883ubjyh.jpg
http://www.abload.de/img/img_6893epk34.jpg
http://www.abload.de/img/img_6428q8knu.jpg
http://www.abload.de/img/img_6374wmkse.jpg
http://www.abload.de/img/img_64154nk6c.jpg
New rad size incoming :)
http://www.abload.de/img/img_45634rlju.jpg
http://www.abload.de/img/img_4584alyma.jpg
http://www.abload.de/img/img_45925wyc0.jpg
http://www.abload.de/img/img_4598qmlai.jpg
Name 3 cases where it fits in the top w/o modding ! :)
ATCS 840..? maybe HAF X
edit: will not work without modding, 5,25'' bays get in the way.
But, if you take HAF X case, remove 5,25'' bays entirely, you can put two such rads inside easily :)
This is haf 932 model, but frame is exact same as haf x, and haf x has better top panel for this, since it has two 200mm vent holes.
http://img849.imageshack.us/img849/6...2phobya400.gif
Not in the top.. But it will fit in Silverstone FT02 ;)
imo it might be too wide for FT02, a 180mm magicool barely fits. Problem is, that there is recess only for fans, but in order to put rad and fans there, you need to shift both towards side panel.
http://www.abload.de/img/bling37t581.gif
http://www.abload.de/img/img_0259u802f.jpg
http://www.abload.de/img/img_0797kuv96.jpg
http://www.abload.de/img/img_3036bo18s.jpg
http://www.abload.de/img/img_3180z5ve6.jpg
http://www.abload.de/img/img_3486qa54o.jpg
http://www.abload.de/img/img_03340o1xk.jpg
http://www.abload.de/img/img_7838gt6mu.jpg
http://www.abload.de/img/img_8043bf5mj.jpg
http://www.abload.de/img/img_8147k14by.jpg
http://www.abload.de/img/img_8459oa5hl.jpg
http://www.abload.de/img/img_9454d6563.jpg
http://www.abload.de/img/img_9432z0w8b.jpg
http://www.abload.de/img/img_9582la0hh.jpg
http://www.abload.de/img/img_9794ivn6if.jpg
http://www.abload.de/img/img_0294by3p8.jpg
http://www.abload.de/img/img_1619q22ku.jpg
http://www.abload.de/img/img_4863xp6wy.jpg
http://www.abload.de/img/img_51796o18z.jpg
http://www.abload.de/img/img_5458es274.jpg
http://www.abload.de/img/img_5472276bk.jpg
bundymania
There you take Bitspower black carbon? Direct from BP or some else?
Directly from BP
I see.
Thx bundy!
What's the difference between the "Carbon Black" and the "Matte Black" Bitspower fittings? Aside from the red o-ring and the slightly different finish I can't for the life of me see the difference...
yep, thatīs the difference and the fact, that the carbons are not available in any EU shop atm :(
Koolance Day ;)
http://www.abload.de/img/img_3255aflch.jpg
http://www.abload.de/img/img_2730rlxun.jpg
http://www.abload.de/img/img_0514ppa2f.jpg
http://www.abload.de/img/img_553064xff.jpg
http://www.abload.de/img/img_5528kodyaa.jpg
http://www.abload.de/img/img_5637plabq.jpg
Haha, just like AMD and NVIDIA rebranding their GPU's and calling them a "new" series :) Personally I prefer the matte black version, as the green o-ring looks awesome when showing a bit on my rig :)
Also, where do you get all those wonderful toys? You seem to have an endless stream of pictures of component!
Those are very nice parts !
Phobya Xtreme 400 - Performance = better than a 480 Quadrad
http://www.abload.de/img/img_46136jzzk.jpg
