why disable 64bit support? for me crysis gains a few fps on 64bit. :yepp:
@bench2die - I hope you are not using Crysis to test your stability...
1.80v PLL
1.215v QPI/VTT
1.12v IOH
1.66v vDimm
The B chips are stupidly good...
No but if you read the post you would see this..
btw chip does 4.58 through 05 and 06, on water.Quote:
those settings would not pass prime lol it passed it at 4.2 but I upped the voltage some and it passed prime but temps are WAY to high.
http://service.futuremark.com/compare?3dm05=4653713
Ordering my 920 on Friday (finally), Chri$ch is making me want to go with a UD5 now too.
uhn i just noticed that running 8 threads boinc/wcg and gaming does not compute very well. :p:
HT really fills the pipeline and reduces the fps noticable while gaming and running all core on full load.
But i found a easy solution -> reduce boinc to use only 6 threads and assign affinity to cpu 2-7, which leaves cpu 0-1 for games. :D
I even found a tool that let you do this automaticaly. :)
Alright, I've noticed that the max voltages seem to be higher than what people were saying a few weeks ago.
Since theres a lot of confusion would those who have a strong opinion please list the max voltages for QPI (aka UnCore), DRAM, CPU, and PLL please? I'd love to know where I can really push these.
Mine is an #3837A909 HT on, Turbo on.
Stable 200x21 @ 1.3625vCPU & 1.4125vQPI
Ive done hours of gaming, LinX and OCCT so far hasn't locked up yet.
The jump from 190x21 to 200x20 was so huge, I could do 4ghz in below 1.3vCPU.
My max temp I can get is 69-71C when doing LinX, and it idles around 28-30C. This is on water.
Havent tried clocking any higher, might be possible but im worried about the temps.
Should Prime be more stressful than OCCT or LinX?
Very Nice! Heck of an A chip you got there! Whats the batch #, I hope its a cousin of mine ;)
3838b079
http://cfs14.tistory.com/original/2/.../49387a25a184c
http://cfs14.tistory.com/original/10.../49387a25b07f6
BCLK180
http://cfs11.tistory.com/original/25.../493915763c90b
BCLK200
32M pi
http://cfs14.tistory.com/image/7/tis.../49425b11037c9
BCLK221.53
http://cfs13.tistory.com/original/6/.../495aff117def0
EVGA X58 SLI + EVGA GTX260 SLI
http://cfs13.tistory.com/original/22.../495aff119c600
^^^ wow dude, awesome chip, awesome everything. my same board!!!! Congrats!
which eVGA x58 BIOS did you guys use?
Heheh, almost makes me wish I'd gone with a water cooler again.
