I keep it in a separate room since they are too loud.
Here is my play rom atm :-)
http://dl.dropbox.com/u/59552/IMG_3703.JPG
You guys are crazy with your multi-monitor setups. Are those 24"s?
Finally got all main parts watercooled :)
http://img235.imagevenue.com/loc74/t...7_122_74lo.jpg
http://img165.imagevenue.com/loc463/..._122_463lo.jpg
http://img46.imagevenue.com/loc441/t..._122_441lo.jpghttp://img150.imagevenue.com/loc245/..._122_245lo.jpg
http://img287.imagevenue.com/loc501/..._122_501lo.jpghttp://img221.imagevenue.com/loc872/..._122_872lo.jpg
Before:
http://www.upload.ee/thumb/845205/Temp_before.jpg
After:
http://www.upload.ee/thumb/845206/Temp_after.jpg
Before with the fan, chipset temps got to 65-70c IDLE!!!!! srsly cant ASUS make a GOOD stock heatsink for their extreme boards?:
http://img258.imagevenue.com/loc152/..._122_152lo.jpg
Before without the fan, temps got to 85-90c IDLE!!! :lol: I mean wtf, the thermal paste i replaced with MX2, temps got sooo hott... INSANE. ASUS should friggin start making good chipset coolers like Gigabyte.
http://img277.imagevenue.com/loc65/t...e_122_65lo.jpg
I'm trying to figure out what's going on in each screen.......
the thing is what the gpu card setup i can only see 1 bridge conector on the cards so is it 3way x-fire or something i dont know how the radions work with multy gpu's or is it sli with seperate physx
sweet rig by the way cinda want to water cool my rig dont have the confidence to do it :)
3x GTX 460 for folding (F@H I think).
just wondering is there a really good 3rd party cooler for the gtx 470
i had a thermalright cooler for my old gtx 280 but after i fitted it the memory got so hot the screen wold go brown after i put the stock cooler on about 2 weeks later the memory went down
i reall dont want that to happen again
my 2x 470 can hit mid 90s under gaming at 100% fan and i dont kno what to do
any ideas peapole
That is very odd. You have the HAF X which should offer more than enough cooling for even 3 GTX470s..
Did you overvolt it of some sort?
Anyways, this will be a good aftermarket cooler for the Fermis.
My new grafics, ecs gtx460 black. Now, all fans powered by artic cooler
http://img256.imageshack.us/img256/5365/s5033107.jpg
Uploaded with ImageShack.us
http://img412.imageshack.us/img412/5919/s5033109.jpg
i took the heat sink off and relaced the tim with artic silver 5
when im gaming the fans are about 60-70% and the temps hover about 80-88c
but thay are no ware near as loud as thay were
is the cards going to be safe at these temps now do you think
i am thinking of watercooling
but i dont know what sise rad i will need for 2x gtx470 (no overclocking) and a
i7 920 @3.8ghz
i know peapole say go for 2 loops but i priced it up for a single loop and its going to cost £420
ps i have the haf-x case from coolermaster and i can fit a 120.3 rad at the top and a 120.1 at the back
so i can technicly fit a quad rad im my case will that be enugh
(thats the price for the setup is 120.1 rad 120.3 rad 2xblocks for the gpu's
cpu block and waterpump+sump and all the fittings and piping all of it from scan computers)
its alot of money but is it really worth it so shal i go for it or not
FRedzzzz can we get a pic at night with the cathode turned on?? THat's very similar to what i want, i'm going to sleeve everything white and black, already removed the yellow Corsair sticker:D
Already have the 120MM black and white fan, just waiting for Sandy BRidge to get a bigger cooler that will fit with it. :up:
Yes, this my old system within gtx 285
http://img338.imageshack.us/img338/646/s5033096.jpg
Modded Lianli PC-A06B with 6 hdd slots for my server :D
http://koti.mbnet.fi/ipe91/b/2.JPG
Nothing really fancy here. Had to remove the "light" from the front panel of the case to impove airflow a little.
