Thanks mate , its high until I sort this out then I will try for min volts at 4ghz .
I found something interesting and I hope someone can explain this to me. After struggling for a few days since install to get my rig stable at 4Ghz+ I tried different ram and its stable now with no other changes. I was using ballistix 6400 at stock speed and fsb at 400 thanks to qx's unlocked multi , at 3600 its prime stable for as long as you want to run it , bump the multi from 9x to 10x and this issue starts . Now with fsb/ram speeds the same shouldnt stability etc be the same ? Before swapping the rams I memtested the ballistix overnight and passed 17 passes, so can you have a ram compatibility issue only at high cpu clocks ? With 6400 Teams in it now its primed for 6hrs. How does ram cause this if its not showing any other problems ?
What setting in bios is it that allows me to reduce vcore ?
:shrug:
