You just had to do it, didn't you?! :D
Well, that's very impressive! Using SP1 on air! Great chip! :up:
Please red the rules once again, mate. :)
My i7 920 3946A169 under water with 1.4375v set in bios.
http://i.imgur.com/D3IKE.jpg
Can I add my i7 2600K @ 5.0 Ghz.:)
Batch L038A660
Asus P8P67 Deluxe. Bios 1253.
Cooling Air.
Vcore 1.416v.
1.405 set in bios.
Chip may go higher but max temp on air.
4C4T SP1.
@ C-N nice clocks. I don't have the b#lls for that kind of voltage.
I'm in the club if i didn't forget any of the rules....:D
http://i765.photobucket.com/albums/x...passstable.png
Cooled on water,using 1.504 volts under load at 4.56Ghz for the CPU,and the motherboard is a Gigabyte X58 UD5(revision 1.0).....
He he... I just get carried away :D
LOL me neither I just ignore it.... pretend its not real!!!!
Seriously though how many Intel chips have you ever blown up? I think if the chip still scales then its happy to do it but ye its pushing air a bit.
A very late 920 comer... :D
http://img198.imageshack.us/img198/2...inxstable3.jpg
One more a bit late and outside the rules... :p:
http://img87.imageshack.us/img87/954...stable4.th.jpg
System in sig.
Joining the club a second time :D
2600k Batch L040B705
Gigabyte GA-P67A-UD7
Water Cooling
Vcore 1.391v.
1.420 set in bios.
Dont feel the need to go higher than 5.0 . . Ran LinX 2 X 20 times
http://i84.photobucket.com/albums/k7...19-14-48PM.png
Scum | Core i7 980X [6C 6T] @ 4510 MHz | 1.4 | ASUS Rampage III Extreme | Air| 3031A242
http://img232.imageshack.us/img232/8561/linx45.png
Hey ya all you crazy Sandy biтches, leave our club and get your own 5.5Ghz Linx Stable!!! ............... Just kiddin :welcome: nice results. :up: maybe next update will be for 6ghz stable :rolleyes:
Asus Rampage 3 Extreme -Water
980x Water 1.475v
Still tweeking settings
http://i939.photobucket.com/albums/a...bel/Linx45.jpg
I was close to successful run but the NB overheated :)(it was on stock cooling). That was only 1 try didn't try for lower VCore(1.504 load) or higher frequency(cause of the high FSB). I hope to complete it successfully next time when I have more time to play :P.
http://img713.imageshack.us/img713/6589/linxfail.jpg
The OP has been updated! Good job, everyone, and welcome to the new members. :)
Great formatting. Please read the rules once again, though, LinX has to be running in order to join. :)
Please read the rules, also. Added a big red part, hope it's gonna help avoid this. :up:
Holy cow, what kinda cooling are you running there?! :eek:
That's would be my suggestion, also. :up:
You can run it at, say, 4.2GHz, let it finish, then use some utility (like CPU Tweaker) to OC it to 4.5GHz, and take a screenshot. Then claim that LinX is terrible at utilising HT, or whatever (hence low GFlops). Basically, an easy legitimacy check. :)
Just set it to 21 pass, and take a screenshot a couple of seconds after it's done with the 20th pass, job done! :up:
[QUOTE=thobel;4722836]Asus Rampage 3 Extreme -Water
980x Water 1.475v
http://i939.photobucket.com/albums/a...el/linx451.jpg
