Originally posted by Ace-a-Rue
Pretty nice band of numbers you posted there Hipro5.....:)
Here is a simple look at the IC Vdimm regulator and my way to measure the Vdimm. I used a Radio Shack 10K miniature POT(set to max 10K). With the Vdimm set to 2.5 in the bios I get about 2.70-2.72. Then I use the bios to adjust the Vdimm upwards to a max for me of 2.94v. Now, I can go higher but then I have to adjust the POT to a lower resistance to raise the Vdimm above the 2.94.
I use the bios settings in conjunction with the 10K attached pot if the SMD grabber becomes disconnected. At least I will have some higher Vdimm than just 2.5v. Actually, my board was overvolting in the Vdimm by about 0.078.
Is the SMD grabber with the tape on it measuring the V-dimm volts?
