I don't really know any noise stats but mjgent pmed me and said the RD-30 was slightly louder than the RD-20. I think they would both be relatively quiet when undervoltedQuote:
How big is this thing? I can't seem to find the dimension measurements.
pretty small actually. Incredibly small for what it does too.
http://img152.imageshack.us/img152/8897/specs2mp.png
What I want to know is what shipping will be used to order them on monday, trying to figure out how soon I can get my hands on mine :slobber:
nikhsub1 will the meanwells fit in the hard drive rack on the Mountainmod case? I remembered a while ago with you having a picture of a meanwell fitting in there.
So, getting close to order point. How many are in on the buy?
I have been doing some searching. Will we be able to get a groupbuy on the meanwell ac-dc powersupply aswell? I for one would like to have a separate supply, instead of drawing on the excisting powersupply.
On the meanwells site they have the following prices on the S-240 series:
1-9 ~$108
10-24 ~$92
25-99 ~82
So if more than 10 needs it, we are looking at 15% off :)
And in the unlikely event that 25 needs it, almost 25% off...
EDIT: for the record... I did not offer to arrange the buy... as it would be extra costly to ship the stuff over here first. Would have to be someone local :)
count me in for one of the S-240-24's :)
yeah, I guess I could get in on that meanwell action too if you guys setup a group buy. except I think the s-200 is prob powerful enough for our application guys. I would personally go in on a group buy for that.
after all is said and done, we've got 16 pumps being ordered as of right now. For the record, only 2 ppl are going with rd-20's .. woo...!
Well, in the end for 15$ bucks more you get to put "30" in your sig, and get same or better performance than a 20 with a pump that will last longer (undervolted), undervolting which is not a problem because were all gonna need converters or transformers anyway... :D
You gonna keep your 20 or switch to a 30?
So is really, really RD-30 as silent as RD-20 when both are undervolted performing the same (same flow rate, head pressure etc)? Because if they are of course the RD-30 is a better decision (since undervolting is possible). If RD-20 is indeed more silent than RD-30 at the same flow rate (performance), then I'm staying with my RD-20. Anyone know for sure?
I don't see the s-200 on the pages, but they do have a s-210 that has 8.8A on the 24V. Isn't the RD-30 rated as 10A startup?Quote:
Originally Posted by fareastgq
If that would be enough, they start at ~$71, ~$59 for 10+. Not that bad really.. Come on guys! Could someone check with them regarding the startup current?
Dont matter, you dont need to cover for the full startup current. Something like half of it is fine.
I see.
Well then, looks like I'll be in on the s-210-24, if someone (pretty please) decides to get it. :toast:
Does anyone know if there is the possibility of the RD-20 being actually LOUDER than the RD-20? If RD-20 is as silent as the RD-30 or even quieter than the RD-30, then I'll definitely stay with the RD-20. (NOTE: This would be at the same performance of course!!)
http://www.anonforums.com/builds/bla...rd30/24psu.jpgQuote:
Originally Posted by situman
krille, stick with the rd-30 :) You won't hear either pump over your psu fan. Sorry I meant 200 series, so yeah, that would be the s-210 or the sp-210. Honestly, if you guys want, I'll setup a group buy for a s-150, as that's all any of us need, that would prob be about another 10 bux off making it about 35 bux+ ship for us all. If you guys want to do this I can arrange that also. I'll need to call around to see where we can get the lowest prices possible. And I'm keeping my RD-20 and the 30, I need to run tests for both. I might have a mini review comparing the 2 pumps later :)
Grrrrrrr.... so hard decision! I really want silence, but if one can bring both for only $15 more of course it's worth it. But is the RD-30 really, really, really just as silent? And btw, did you really mean the fan of my Seasonic S12 600 (around 25 dBA during normal usage) will render the RD-30 inaudible? Because that just sounds too good to be true.
What is the difference between the RD-20 and RD-30 really?
Main difference:Quote:
Originally Posted by krille
You should order the RD-30, whereas the RD-20 you shouldn't. Period.
No, really. Is RD-30 just higher quality, or has it got noisier parts? I'm interested in the difference since I'm more than willing to get the RD-30 if I can get it just as silent as the RD-20 at the same performance. :)Quote:
Originally Posted by HiJon89
well, I'm sure a zalman vga fan on full blast isn't more than 25dbs, so yeah. My psu fan is about 35db I think, I'm running the stock amd fan on my zippy 700 :) Buy the rd-30, undervolt it to 17-21v and your good to go.
Just out of curiosity, may I ask which Zalman VGA HSF you got? Btw... how long are you staying online (ie so I know how much time I got to decide)?
Let's say you have an RD-30 and RD-20, both at 24V. RD-30 will perform better, but will be noisier. You could lower the RD-30 to, say, 20V and it will probably still perform better, but be quieter.Quote:
Ok, this is what I'll do. My father really wants me to go to bed now, so I'll buy both and then I can see for myself which one I like the best. :)
Thanks. I was worried where I would mount the thing.Quote:
Originally Posted by nikhsub1
Do we have pumps incoming? :)
where is my pump :stick:
*bangs his fork and knife on the table*
