SO how long till US release
This week I hear, i have just recieved one as well as Wesley off anandtech, he will review it soon to coinside with the launch.
There are a lot of options on this board, I see a lot of you asking a lot of questons as soon as you get it, IE we only just got used to 15 levels of drive...now we have a lot more than that ;)32 :eek: VDimm almost on 0.01steps from 2V to 3 V then it jumps in .03V steps to 4.15V.
This really is looking to be the ultimate ddr1 motherboard, and just shows why waiting for Oskar and DFI is usually worth the wait.
They are available to pre-order in UK , so hope to have one early next week :)
just found out the price ,equivalent to 253 Euros :(
£176! Not a chance in hell!
I think you have been looking at the same store ,lolQuote:
Originally Posted by Draxx
Not to far from you it seems ;)
This motherboard will be best seller.
I'm waiting mine tommorow
Can't wait..
I am ready to set up a my rig based on 2*X1900XT CF mode.
I am waiting for this board so I can go CrossFire as well.
Also I just ordered a new Opteron 170 and hopefully I can get some nice clocks from it.
Me waiting Too...:rolleyes:
With my "poor" Opty 146 and an ATI X1900XT...
What is the result of the Sapphire not having this? What will be the difference?Quote:
Originally Posted by Tony
So if just considering the OC capability and general performance, I assume this motherboard is superior to the Sapphire?
I promised myself no more upgrades till next year.. but I don't know if I can wait :slap:
:) Same hereQuote:
Originally Posted by ahmad
Now oblivion with mods needs more than 256 vram :(:( I need this board and another x1800xt 256 so I can play it in full glory (that's how I'll justify it to myself.... and the missus lol) :slapass:
Hey guys, does this board have the Japanese aluminum capacitors that the Venus has?
this board seems pretty amazing, hopefully the price wont be too bad......actually who cares, im buying it no matter what!
peace :cool:
I just bought an asus ar832 mvp.....must not buy:)
I've been trying to tell folks the same thing Tony. It seems like a hard message to get across. Folks just want to use Ultra D/SLI DR settings.:slapass:Quote:
Anyways, this new board does look very nice indeed.
On the site with UK preorder it lists it as having "100% Japanese Capacitors".Quote:
Originally Posted by TheReds
G
Can someone tell me if this board supports 4x1GB ram@1T?!...
I have Gskill HZ....
I believe it does...
Look here... http://www.xtremesystems.org/forums/...6&postcount=14
Thanks. It seems that DFI CFX3200 is able to support 4x1GB ram@1T.... But i find it difficult to equal the OC performance of a 2x1GB ram@1T... That would be great.Quote:
Originally Posted by ugp
Best Regards
At the moment boards advertising 4*1gb @1t can only do it just above stock ~205mhzQuote:
Originally Posted by JohnMike
Does the RD580 chipset still suffer from lower single-card performance relative to an NF4 chipset? I am interested in this board but do not plan on going crossfire, this would be only for improving overclocking and such. The whole issue, however, is I wont be interested if it scores lower @ same settings in single card mode than and Ultra-D or expert.
You mean, i can´t go futher than 205mhz?!...Even with OC on it?!Quote:
Originally Posted by Vincentvega18
If that's the case, i must use dividers and go for OC on CPU only. But should the dividers with 4*1GB @1T performance well as it does with 2+1GB @1T?!
Best regards
JohnMike,
No, there's no "limit" if that's what you mean.
The board can likely run 4*ds sticks 1T at 200MHz, as optimised board design decreases signal corruption/whatever which hinders memory controller's stability. There's no magical mobo design that could make K8 memory controller magically handle that amount of ranks at 1T and >>200MHz.
The actual problem in this matter is the K8 IMC, not board design.
