This is the OC competition by DFI own
Ultra-D/SLI-DR created the TCCD top limitation
EXPERT improved the PCI-E gaps, over 3.3V with non-segment, re-positioned DRAM slots, Winbond UTT become better but lost some compatibility with TCCD.
Venus inherit EXPERT all advantages and plus 100% aluminum capacitors, improved TCCD compatibility (a little bit weaker than Ultra-D)
Enhance 4DIMM OC ability dramatically and make 2GB OC become better.
Nowadays, 2GB is the mainstream. Venus’s advantages are much bigger than weakness.
Well if it is such a larger improvement in the areas you state, why is it only going to be a small limited edition run than?
