Very nice clocks and scores Gorod. Is 2.001v the optimum for the vmem in your testing? Are you getting instability with increased volts?
My card will max out the memory at 810 using only 2.001. My memory controller craps out before I need more voltage.
Thank you :toast: Ya i get less artifacts if i lower volts for video memory and it gets more stable , also it hates heat and a 120mm fan blowing on helps a bit :) http://img155.imageshack.us/img155/6312/0014ud.th.jpg , using OveclockerX1K insted of ATITool helps getting higher mem. clocks too , but it increases timings , anyway it works better for 3D01 for me , didn't check what is better (MHz Vs timings) for other 3dmarks yet :rolleyes:Quote:
Originally Posted by Kesnel
lower mhz but tighter timings is great for 05 and 06, but higher mhz seems to do better for 01, 03 and aquamark.
AquaMark3 won't even run under Windows XP 64-Bit...
I have been doing alittle testing with it lately...
