Around 17C, I've gone way cooler. With some 10-12C room temps, Im sure I can Spi1mb @ 5000mhz and get 25 seconds!Quote:
No luck, my temps really suck, I guess I don't have a real good water cooling system or my 930 plainly sucks or my memory, or my PSU. I'll just hold on to it until the next batch come out. Thanks for all your help.
Finally got around to running a 32M SPi on my 661....it does VERY well on this bench ;) The settings for this are a tad slower than I use for 1M (23.313s), but if I can get it to match, it will be SO close to making a 19m xxx pull. I'll keep working on it.
Sorry the bottom is cut off, I forgot to pull the window open taller before I started it :(
http://i10.photobucket.com/albums/a1...32_2035984.gif
For the record, here is that SPi 1M:
http://i10.photobucket.com/albums/a1..._spi_23313.gif
boostedevo, thats a great score ! 661 on H20 or Vapo ? and those Mushkin sticks pawn every DDR2 !
You have Vdimm mod for that ?
boostedevo
nice ,very nice Cedarmill u got there ,im waiting for a same 661 and with some lucky @ 5ghz+ stable on water
it's a cold night in Japan and good time for some suicide screens and benchs.
http://img75.imageshack.us/img75/732...slerpi21lw.jpg
ORB #1 6800GT/Ultra non SLI class
3d06
Presler @ 4.4ghz
6800GT @ Ultra
3495 3dmarks
http://service.futuremark.com/compare?3dm06=45981
http://valid.x86-secret.com/ccpuz.php?id=65723
http://valid.x86-secret.com/show_oc?id=65723
on water ;)
http://valid.x86-secret.com/show_oc?id=65677
Thanks guys! The Mushkin definitely goes a LONG way in helping ;)
Iluv, yes 2.45V.
PcCI, if it's anything like mine, you'll love it ;) I've seen some 641s getting close to the 5GHz on air mark (suicides), so all CMs may be very strong clockers. Mine did 5GHz stable on water/5.2GHz suicide @ 1.55Vc That's a nice time for the 930.
Unseen, that's awesome. I am sure there's a bunch of Vc behind that ;) I stopped at 1.50Vc actual and couldn't even get 5GHz on phase out of mine 930 :( I am a little more giving with the Vc on the 661 and it pays off. I am giving some serious thought to picking up a 920 just to redeem myself for the lack of Vc on 930 ;) Nice clock!
To everyone, are all you OC from BIOS, from windows, or a combination of both??
Bios 0704Quote:
Originally Posted by nicepun
4.5ghz @ 300 x 15 @ 1.475v or more
and from it i use AIBooster to pump only the clocks
which version of AIBooster? 2.00.62 ?
Cheers :)
2.00.70
Here it is mine at -45 (on load)
http://img223.imageshack.us/img223/7076/1m53012vj.jpg
nickie i think it is wr for now? Can i post it in the right thread?
sorry but i forgot to take a validation... I am on water again now...
Well valid link isn't necessary so I can add it as WR congrats, cooling? Single Stage?
Here's my Presly @ 4.5GHz cooled by some cruddy Zalman air thing - friggin 35C ambient here in Sydney - last night was cold though :D.
CPU was 4C colder (from 60C to 56C :P) last night at equal clocks, gave me 200MHz.
It's 1M PI stable up to 4.6 but seemed to have lost my screeny of that - will make another if tonight is as cold as last night.
http://valid.x86-secret.com/show_oc?id=66001
Only the CPU clock is accurate on that - the multi is like at 23 or something and the FSB lower appropriately, and thus the ram lower as well (nah I don't have DDR1250 3-2-2-4 capable sticks :( :P)
There's like some national shortage of tubing for my watercooling stuff down here in Aus :( :P)
http://service.futuremark.com/compare?2k1=8874914
There's 3d.
http://img216.imageshack.us/img216/2928/46005vq.jpg
4.6Ghz action
boostedevo, did you come up against a wall with Vcore on 661 when getting maximum stable O/C ? if so what was it ?
Still got to wait another 2 weeks before mine comes...:(
2 nights of tests
Reserator + single rad/Vantec Tornado
Hiroshima Japan -2c
http://img229.imageshack.us/img229/6...slerpi23nr.jpg
http://i28.photobucket.com/albums/c2...resler4880.jpg
http://valid.x86-secret.com/show_oc?id=65989
Hiroshima Japan -5c
http://img61.imageshack.us/img61/671...ixatemp1eb.jpg
PcCI2iminal,
vgood results man :)
though, SPI32mb seems very low, 32mins?, mine does26mins @ 4.2Ghz :confused:
edited/ sorry my mistake... just saw that that bench done was at stock speeds ;)
anyone know how i could get my voltage to show up on cpuz?
Im using the latest version
On water 4.85-5.00GHz was a problem. 5GHz took 1.55Vc to be stable and I have a feeling it would be even happier with more :)Quote:
On phase, 5.3GHz really seems to be the next one. It's completed PCMark04 @ 5.4GHz with 1.55Vc, but again, I get the distinct impression, it would like some more juice there. I've tried as high as 1.60Vc and still cannot get it to pass a PCMark04 any higher than that though...capacity may be coming into play as well at that Vc/clock level...
It will run SPi 1M almost at 5.6GHz, but 32M is more like in the 5.4GHz range like PCMark04.
I have a screen shot at 5858MHz and got it in just in time before it crashed, LOL. Maybe with some better cooling or more Vc it would hit the 6GHz mark and/or bench higher, but I have not tried more than 1.62Vc (actual) for anything other than that suicide shot...
OK, boostedevo... very interesting !
My poor little 630 has to have 1.60 Vcore to run @ 4.3ghz with Crystalmark 0.9.117 and 3Dmark01, 03, 05 cpu tests. It does'nt like anything above 4.27 for PCmark04 unless I turn off HT.
However these are only early days with high end off-the-shelf water cooling for me... :)
Keep up the good O/C's ! ;)
im testing Presler @ undervolt ,18-21C @ full load is amazing for a dual core ( room temps help me alot :D )
ProphetX
must be the 1.31 version,1.30 version shows Presler=Pentium 4 and no vcore
http://www.cpuid.com/download/cpu-z-131.zip
That's actually a pretty good clock for a 630 on water...I am surprised that it's even stable enough for benches at 4.3, so it's doing well. I tried a 630 once and didn't have a lot of luck with it at all...Quote:
Originally Posted by PcCI2iminal
im using version 1.31
My first OC with my 920D, after a few hours....
I'm using Air Cooling (XP90c + NB SX2) and only 1.37Vcore
(Click and see)
http://img92.imageshack.us/img92/3808/2teste4id.th.jpg
http://img92.imageshack.us/img92/280...cont8bx.th.jpg
http://img92.imageshack.us/img92/664...with1ij.th.jpg
http://img92.imageshack.us/img92/2724/write2vk.th.jpg
http://img92.imageshack.us/img92/4421/latency2fw.th.jpg
I think with this vcore i could make even a better OC but tomorow i'll find out!
