pensil Vmod on chip +24 MHz = 729
pensil Vmod on ram +0 Mhz :(
timings is nornal
I need PowerColor x1300 PRO BIOS
timings is nornal
My mistake....the chips are actually Infineon 2.5ns.Quote:
Originally Posted by DrJay
hynix 2.5ns here. Thing is that sometimes is working, but lately with only 1MHz is doing several artefacts and freeze or black screens. Softmodded Catalyst 6.4 or Extreme-ATI 1.6.3 and AtiTool 0.25beta14. What do you use?Quote:
VoltModded, 1.73V on GPU (0.5KOhm), 2.26V on Mem(10KOhm).
And I do have now WR on 3D2005 and 3D2006, i will validate later. :D
As I mentioned, they were actually Infineon 2.5ns chips. I used a combination of OCtool, Rivatuner and ATItool. At least I think I did........it has been several months now.
Hi there guys,
i've been reading this tread and was speachless ! You're my idols :D Those results were simply incredible. I've got a small barage of questions for you all, because i'm planing on buying Sapphire x1300 n-p:
1.Do i need water cooling if i'm gonna volt-mod the core
2.How much does memory speed affect the performance (if u could post parallel result or tell me cca. in percent - eg. 5%...)
3.When you say 5kOhm resistor you actually mean 5000 Ohm or 500Ohm ?
4.What is the optimal voltage for core/memory
Well, sorry for posting so much Qs but i'm kinda scared of frying my Sapp. x1300 np. Thanx guys in advance.
5k Ohm = 5000 OhmQuote:
Originally Posted by demios
Voltage Modification Guide For Sapphire X1600PRO 256MB the got it 800.. that was a sapphire do...Quote:
Originally Posted by sabrewolf732
Tnx jumanji969, i thought so, but i just wanted to make sure ;)
whats the max 05 score of this v-modded cards then?
I bought the damn thing - Sapphire x1300 256mb 2.8ns (65e) On stock volts it does 650/890 !!! And I get cca. 2850 in '05 (because i have weak system memory, but i guess i'd get cca. 3000 with some normal mem). I installed 8cm fan on the front and added some passive sinks on the back memory chips, i also hang another 8cm fan to cool the back side of the card. Now, I understand that i need to vomd core, but i'd rather do it /w pencil than resistor. So I'd kindly ask someone of you to draw me :D where i need to make a line /w pencil. I know i ask too much, but srry the card is cold all the time - it want's to get modded, please help her ;)
Tnx guys.
edit:
if i flash it /w PRO bios, will i get higher voltages ? or if i edit this bios ?
Can someone give me Sapphire x1300 pro bios ? tnx
so where is the volt mod guide?
please post the gigabyte x1300 pro voltmod.
