Originally posted by bowman1964
Well thats how it used to work.say your power supply is putting out 5.07v measured at a molex connector.and the mofset only shows 4.85 measured at the mofset itself.now that tell us that the board is losing voltage somewhere.normally thats why you see the power feed plug close to the mofsets so they get better current.now i have before soldered a wire to the feed to the mofsets them self and plugged into the 5v side of the power supply.on the old motherboards i could pick up a few mhz and stablity doing so.but i havent had to do that latley because of better built boards.and to be honest i forgot about it until today.
i am not saying it will even work on these new boards but the principle is the same.and heat in the mofsets can be caused by resistance in the current flow to them.low voltage is a big cause of heat in a circuit.
but i will try to check mine tonight
