:clap: and?Quote:
Originally Posted by situman
you cant use 2 of the 3 pci slots on the a8n32 unless you have single slot coolers and want them to idle at 70c+ and dual slot (512gtx/some air coolers/watercooling) means the pci card that goes in the middle gets some serious heat.
you only need 1 pci slot for xfi, and thats at the bottom. :fact:
so you can use xfi and dual slot cooling now, the expert has the best layout with up to 2 pci slots that can be used but and also itsnt comparable due to different chipset used and that it kills cpu's
besides, apart from a tv card, i cant think of anything else most people would need to put there.
i though most people here had separate media rigs anyway :stick:
(rig 1=omgamdgamerrigandoverclockedrig)
(rig 2=stable media rig with loads'o'space and a tv card)
