Originally Posted by bachus_anonym
I'm seeing that some of you guys miss the point of this thread. I will add to what s7e9h3n said, to make it more clear:
"The goal is to use the least CPU MHz possible to break into certain time zones. Posting a result, like 20:33 or 20:10 does not make sense at all. One needs to post time from e.g. 20.55.xxx to 20.59.xxx, and certainly not 21:02:xxx ;) The goal is to barely squeeze right below a 21:00 (or 22:00, 23:00, 24:00, etc). As an example, dinoss22's result (post #143) is perfect but Unseen's (post #142) does not fit here at all ;) I say we should be taking under consideration only results within 5s below, e.g. 20:55.000 to 20:59.999..."
