How'd you get on Randi??
Hi everbody,i'm pretty new to this,i've just got an nf7-s and two 256mb ocz el's which i will use in dual mode,with my 1800xp what sort of fsb speeds should i be able to reach with out any volt mods?
be more specific..Quote:
Originally posted by beatnic
different cpu. :cool:
btw MrIcee niiiiiiccee board cooling you got there :slobber:
Twiggy's bro probably didnt' have sufficient amount of Vcore for the CPU, or his memory voltage, or his HDD is not being able to handle the PCI bus speed depending on how he setup his AGP/PCI speed in the BIOS. Maybe he set it too high? i.e. 49~ 49.5mhz PCI? Any one of these, or combination of all this "can" cause file corrupt also.
Just an update:
I uninstalled all drivers and installed the ones of the ABIT CD..what a pain in the arse. I also upped my Vdd to 2v and applied 3.2v to the memory..and walla !!
Benching 3DMark stably at 217Mhz no problem....added about 250 points to my Ti4200 score in the process, heres a little 2600Mhz and under action...onwards and upwards !!!
Randi:D
Heres how my testing and mods have left me so far in the complete Ti4200 class, with CPU still on air. Once I move it all back into the Prometeia I should be able to get close to macci. I'm a bit handicapped with the ABIT Siluro OTES Ti4200 as the Hynix memory is not very good, topping out at 670Mhz @ 4v. A card with better memory up in the 740Mhz range would level the playing field as far as the card is concerned:)
Randi:D
But Randi,Quote:
Randi:D
Once you go to the Prome... Will you be limited by the Vcore as I am with the 8RDA+ ? If you can't raise the Vcore to above 2.0v Then it Negates the advantage of the Prome, I might as well stay on air.
And I have Heatsinks and a fan on all the Mosfets..
RoydRage
No diff setting. All the setting were the same. Tried it with the AGP locked and still no dice. I know its not voltage cause I ran it at 217(217x11 and my bro tried the same too) all the time and never really had any probs. The only mod done on the board is the vcore mod. No matter what he cant get past 205 and I know for a fact his parts are good for it, but anyway the board is comin back to me so I can test it out more. I wish I had a 2700+ so I could fiddle with it but o well.Quote:
Originally posted by IamAnoobieCheez
be more specific..
:toast:
Bludgeon the Intels!
With the chip I have now..I can run 2700Mhz+ at 2v in the Prom. I have already with this chip. But in the meantime..I am trying to overcome the OVP problem on the Vcore. I'll keep you posted:)
Randi:D
MrIcee,
Is another G4 an option? I have my Abit Siluro(4ns Hynix) @ 357/695 on AIR w/ vmod...no ramsinks. That card is def. holding you back in the Ti4200 class...no idea why the OTES doesn't clock as well as the original. :)
P.S. I know ur busy, but I'm just remindin ya about the PM I sent ya again :p
N8:)
Yep..I got the screenshots for ya..I'll get em off to you this evening...got the family thing going at the moment:)
I PROMISE:D
Randi:D
PS. How much voltage you pumping through your memory...I'm using 4v and am not sure whatthe safe limit is.
BBL y'all...............................
After 4v, my 3DMark score goes down. I've tried up to 4.1v & after something like 4.02v I saw a sizable decrease in my 3DMark score. This was some months ago so I'm doing my best to remember. But I know I had it @ 4v to run the score in my sig back then @ 695MHz. This was with no ramsinks. I've since bought some tweakmonster ones but I haven't had time to put them on...I'm hoping they give me another 15MHz w/ the vmod applied. I've run some benches in the past week but all have been w/o the vmod attached ;)
The 1 weird thing I remembered about the vmod was that I couldn't have artifacting w/ it attached. If I saw any artifacting I couldn't finish the tests...I believe it hard-locked...not positive. :)
Almost forgot about this bench :D Check it out 233x11.5 Dual Kingston, well over 21000 at less then 2700Mhz:D Not bad!!
OPP
Way to go my man:toast:
Damn impressive:thumbsup:
What kind of chipset and memory voltage are you running to get that puppy to do 3D at that FSB?? I'm at 2v Vdd and 3.2Vmem to bench at 217-220 max timings.
Randi:D
I ran this at 1.87V Vdd and 3.11V on the mem :)Quote:
Randi:D
OPP
Got to agree with Randi there that that is a damn impressive mem bench, no doubt. Keep the dream alive (almost that time again).
How is the mod comming?
icee and opp or anyone else who is using this board. can you use the 8.0-10.5mults with a high fsb?
i am experiencing a big problem with the nf7 i just purchased. i have a 1700+ tbred.
i can run 7.5x211. however i can not boot into windows (it will post) at any mult 8.0-10.5 with a fsb a SINGLE MHZ HIGHER than 166.
with 11.0 and 11.5 it works fine as right now i am runnin 11.0x175 (the highest i can get stable, but i can boot into windows at up to 11.0x183)
WTF Is wrong w/ my board??? here is a thread i started at abit:
http://forum.abit-usa.com/showthread...2&goto=newpost
I have the same problem, by 2 best multipliers are 11 and 13. When I unhook my v-core mod I can boot with all multipliers but can't go very high with the fsb, some more then others. With it hooked up I can't even get into windows with most multipliers. The only 2 that work flawless are 11 and 13, not sure why.
OPP
I overcame the problem with the multi's when I updated to the beta 13 bios. Not sure why but the only multi's I had after cutting the L12 bridge on my 2700+ running the 12 bios were 5x, 11x and 13x, from 13x and below. After updating to the beta 13 bios all multi's under 13x worked and at any FSB speed...this is with the Vcore mod hooked up also.:)
Marty:)
I'll get the Vdd mod published soon...have been way busy this last week involved with stuff for Xtreme and in my personal life/job. Sorry for the delay:)
Randi:D
I could have sworn I flashed to that bios :confused:
Any word on a OVP mod?? V-core is the only thing holding me back on the NF7 to do some bigger 3D scores.
OPP
I did flash to beta 13 and noticed some improvement on multipliers but 12.5 and 13.5 both suck. With vcore mod in place it is even worse when I turn the voltage up past 1.90 volts.
OPP, congrats ;)
MrIcee, do you have idea when the NF7 rev2 will be available ?
I'm awaiting for it at about 2.5 months :| It seems that they want to get rid of the stock of the rev1 :(
btw, can you tell me some more about that SILURO OTES mod ? I would apreciate it :)
Just curious if anyone knew what the VDD was on the KD7. I am beginning to think that my §§§§ty OC mhz wise is do to the 1.7 VDD. As a matter of fact since Vcore is lower than what you set it in the bios maybe VDD is also lower. Maybe the VDD goes even lower as you turn up the Vcore with the pin 7 mod. Any ideas? Or could someone who knows where to measure the VDD please check this out.
Got me a 1700+ AIUGA Wk47, and have same problem on my kx7!
Do not know what to do. Booting fine with 133FSB and all multis up to 12,5 working. But if switching to any thing above 166/200FSB is definitely not stable and often not even getting into windows (reboots) :mad:
What to do here?? Thought of buying a NF7 and HPT-Raid controller... But if this issue is not solved...
BTW MrIcee,
had same prob with locking screen, flashing and no reaction forcing to reboot with my ti4600 and kx7-r@220FSB+
I am glad not to be the only one ... ;)
Stefan
