Waiting :rolleyes:
Waiting :rolleyes:
Any signs of dual core Opteron results somewhere??
no noticable difference. back to ram testing :DQuote:
Originally Posted by ozzimark
my question as well........still looking to find a Dual Core OC results somewhere.....even PRTeamJapan has no results :(Quote:
Originally Posted by Mats
If the dual core operton are like the single, they will run HOT. I had a x2 3800 and when running prime it would hit close to 60c with very good air. This 144 at 1.4 runs as hot as my 3700sd at 1.6.Quote:
Originally Posted by dinos22
One or two instances running (last graph)?Quote:
Originally Posted by dogsx2
It was a 3800 toledo and ran hot running one and about 60c running two.Quote:
Anybody wanna try overclocking the 175?
http://www.onsale.com/onsale/shop/de...d=BWBPRICEGRAB
It says call them for stock info, but I got no time for this. Somebody do it for me lol. g2g bye.
________
AROMED VAPORIZER
with orange slots, same settings as last time.. kinda curious results. i found that a small number of errors normally occured on the first pass, so i recorded the first and second pass.Quote:
Originally Posted by afireinside
seems that 7.0ns wins in the orange slots. 261mhz acted reaaalll strange though, random dumps in memtest and suchCode:4.0ns = no memtest
4.5ns = 0 + 73
5.0ns = 2 + 78
5.5ns = 4 + 72
6.0ns = 2 + crash
6.5ns = 10 + 118
7.0ns = 0 + 0
7.5ns = no post
currently oc'ing the opteron with the single sided stick of bh-5, just to see if the ram had any impact in the clocks.
Just slapped my 2gig set of Patriot Infineon in. No time to tweak. I'll try tommorow. Hoping to go with a 3:4 divider and bring up the memory closer to its potential and get 32M stable.
http://img250.imageshack.us/img250/6...x934div1lx.png
First of all let me explain what mobo/ram i used and what i've done
Specs:
MSI K8N Neo4 Plat/NonSLI
2x512mb G.Skill LE
I was hoping to hit a good HTT with the 10x multi but i couldn't. The voltage options on this mobo aren't that great. If I tried doing 1.4 + 20% (1.680v) the system hard locked and I had to reset the CMOS. The max volt's it would take was 1.4 + 16.6% (1.632v) but in CPUID it reports it as hovering 1.552. Very odd. I don't have a64 tweaker so i can't do a more complex SS. I used ClockGen to OC it by 1mhz increments until superpi crashed or error'd. Temp's were hovering in the 50c's. Least to say I'm not too happy with the results of OC'ing BUT I'm sure that it's the mobo. I see that everyone here is using DFI for OC'ing and they are right for doing so. those mobo's seem to be more stable then my neo4 :slapass:
The following 2 SS's are the max where superpi didn't fail.
This is with the 9x multi at the MAX FSB that I could do without superpi crashing or windows BSOD'ing or the comp just restarting. I used a 180mhz divider on the RAM.
http://www.supload.com/thumbs/default/maxstable.jpg
The max I could do on the 10x multi was 280 1:1 where superpi finished calculations. I didn't use any dividers with this but i'll go back and try it again maybe with a 133 divider and see what happens.
http://www.supload.com/thumbs/default/maxstable2.jpg
If you guys have any suggestions on what I should do to get a more stable OC then please let me know. Any questions feel free to ask and I'll check back here in about 30 minutes. I'm going to go test out more config's.
i reckon you should start OCing from lower volts up rather than max down because heat may be killing your OCs
I started the cpu @ 250 stock volts 1:1 and it did fine. I guess I'll have to burn in the cpu slowly then (?)
what cooling are you using because those 52C/54C idle temps are criminal man!!!!!!
50s idle?! Damn man, put some cooling on her!
yea 50's were too high. I am using an xp90 w/ 92mm panaflo u1a
well I dropped it to stock volts and slowly worked my way up from 250 in clockgen up to 280 before superpi failed. i then went back into the bios and set it at 280 to boot and superpi'd again and ran prime95 at the same time and tried upping it 1mhz at a time and it failed at loop12 on 281HTT this is all 1:1 here is a screen
http://www.supload.com/thumbs/defaul...tablestock.jpg
FX Speed's :woot: with temps @ 35C this time:cool: high volts were kiling my OC :slap:
edit: i'm gonna go take a shower and let it prime a while then try some more. maybe i'll have some luck afterwards
Originally Posted by asianguy80
:slap: :woot: another monster :toast: :toast:Quote:
Re your 3800 X2 :Quote:
What cooling ("good air" ????) and how high was it clocked to be hitting 60c running 2 instances of prime ??, large or small FFT's ???
The reason I ask is, as per my sig, @ 2.8GHz the most I have been able to heat it up is 48~50c using prime large FFT's
Is yours a cd? I was at 2.8. Read post in this thread for cooling. It's gone down the road, now playing with 144.Quote:
Originally Posted by alpha0ne
High Vcore does not equal high HTT. I think 1.52v is going to be about the top average. I can believe you were in the 50's at 1.68, surprised it didn't die on you. I was mid 40's when I first put it in at 1.5v. I sure hope the 146's do as well as the 144's. It would be nice to run 1:1 on memory.Quote:
Good job, keep posting results.
Team Japan:
S939 Opteron seems has an excellent tolerance at CPU rated voltage.
On the other hand, I found that any higher Vcore would hardly any help to get higher clockspeed
I have some Adata Hynix and Twinmos CH-UTT and BH-UTT. I might get to them at some point, but since these CPUs are going to find homes in gaming rigs eventually, I'm curious whether the memory controllers can handle 2gigs and hope any OC penalty is small. Seems like only the FX CPUs fly with 2x1gig sticks running flat out. In real world gaming I'm sure 2gig > max overclock.Quote:
I'm waiting on the DFI NF4 "Expert" edition and DFI take on the Crossfire mobo. Those may be weeks away so you might have to bite the bullet and get a Ultra-D in the meantime.Quote:
I just hope the 146 clocks as well as my 144. Really looking forward to seeing the before and after temps of Afireinside's Opty after the IHS is removed. My shaky hands and spastic colon won't allow me to consider doing the same. :p:Quote:
What do you think about this? Says shipping next week.
http://www.tankguys.biz/lanparty-cfdr-p-1404.html
Nice find. I've been looking for NCIX to list it as a pre-order. Tank Guys don't have a lot of reviews on Resellerratings but all of the are positive. Tempted to place my pre-order now even though DFI versions of new chipsets have always come to market much later than their rivals. I'd be surprised if they actually ship first week of October. Even if it ships on time ... can you wait that long for a mobo?
Edit: Looks like NCIX has it for pre-order as well. $217.37 with free copy of Bet On Soldier - Blood Sport PC DVD-ROM *AMD Promo* for FREE (a $52 value)
Your right, just ordered a ultra-d from ne.Quote:
Originally Posted by gundamit
Wait a second, I can get a DFI nF4 SLI Infinity for the same money. The reviews I read say they oc pretty good. What do you think?
