yeah collage collage we want our collage xD
You'll have Email in a fewQuote:
Originally Posted by saaya
PSU installed :D wtf? the wires are on the unusual side....lol. Anyway, it's working :p: I keep using the +5V jumper for my memory at the moment cause I wanted to set everything up and running like usual before trying to mess with the jumper to run the memory from the +3.3V line.
They should put a warning that the pots on the OCZ are not some 20 turns one...rofl :D I turned the +12V about 1 quarter and the voltage jumped over 13V, it was the first time I was hearing my CSP-MAP :slap:
http://www.xtremesystems.org/forums/...id=37482&stc=1
Another good news. I reset my GPU waterblock with AS Céramique instead of AS3 and now the temp is around ~40-41C O/C and loaded versus the >60C I was getting before :banana:
got the collage, will post it asap :D
hmmm as3 vs as ceramique shouldnt make a difference of 20°C under load... can you try as3 again and then as ceramique again?
be carefull though if you try it, dont want yo to kill that card :D
I lost my '05 key now the second time.. first, my hdd crashed and second time i forgot, that i reseaved the email again from futuremark and deleted it while i was drunken... :rolleyes:
I love my luck... but don't need em anymore, broke my 8k '05 anyway. :toast: First time ever i won something and i'm to stupid to get the price..
<---- :slapass: :stick:
I did, either Im outta luck with AS3 or that things is no more good after 2-3 years..... maybe it dissolved and it's now mixed like **** :shrug:
thats really odd... so ceramique works better than as3... thats interesting... i thougt they are both the same pretty much...
not really the same, Céramique almost looks like the usual silicone paste they are giving with cheap heatsink except this stuff is thick like butter... AS3 is smoother than that and is easily spreaded vs the Céramique stuff or the AS5 for exemple. I always got good results with AS3 tho, so I think the problem could be the AS3 being too old and not homogenized anymore. No need to say, the AS3 went garbage. Also, the AS3 was electrically conductive, the Céramique stuff is not but is capacitive. It's a pain in the a$$ to remove heatsink/waterblock sticked with Céramique stuff tho once it melt
why you dont use AS5?
