can i use 1 single turn pot, instead the multi-turn ?
i've found it: http://www.rs-components.it/cgi-bin/...rodoid=2313220
thanks
thanks
A single turn VR would work, but it would give you a much less accurate voltage adjustment.Quote:
Originally Posted by gionag
Awesome mod ! Thank you so much ! :toast:
I recently got a booster and man does it jump around, also odd thing, if I turn it all the way up it says 4.1V, hows that possible ? the specs say 3.9V max and for my board (p4c800e) 3.6V :confused:
it seems to be calibrated as at min V it reads 2.6 (while bios is 2.55)
also I was wondering if I may ask a few questions regarding the mod, this being the first time I attempt such a mod, I tried to go shopping, but got stuck on the specs, the selection is rather large and I dont know what to get
here is what Im wondering about:
1. what W for the pot and resistors ? (should I try to get the lowest W possible ?)
2. what V for the cap ? 100uf cap right ? (again should I look for the lowest V possible ?)
3. the opamp is generally hard to pick for me, I dont really know much about them and I have about 30 to choose from, the differences are: amp type (general purpose/low power), features (high-grain, frequency compensated/low power/wide bandwidth), number of circuits (dual/single), package (8-dip/8-soic/8-tssop/8-microsmd) and a few manufacturers like: Fairchild Semiconductor, National Semiconductor, ON Semiconductor, STMicroelectronics and Texas Instruments
I apologize for the number of questions, Im just a bit new to this and I want to get it right
Thank you
Dan
ok in understand. and then, the resistor is 1/8W 1% accuracy ? and the cap is ceramic, it's true ?
thanks for support
The max voltage will increase with a modded booster because of the values of the resistors used to produce a variable reference voltage.Quote:
Originally Posted by ZL1
The power rating of the pot and resistors isn't important. I normally use the smallest resistors I can find tho.Quote:
As long as the capacitor is rated above 5v, there shouldn't be a problem with what voltage rating you use. In the prototype booster, I used 100nf ceramic capacitors, which are usually rated to 50v+, so the voltage rating isn't too important, as long as it is above the expected voltage applied to it :)Quote:
I used an LM358 opamp in my design. Other opamps will probably have a different pin-out to the LM358, so you would have to consider that if you want to use a different opamp.Quote:
The LM358 is a general purpose dual opamp (it has 2 opamps in one package). I chose the LM358 because I had them to hand when I was modding the first booster, and they are relitively low cost.
If you are quite new to soldering/modding, I would suggest getting a 8-pin dip package opamp. The other packages are likely to be smaller and harder to solder to. The manufacturer of the opamp isn't important. An LM358 opamp will do the same job and have the same specs, no matter who the manufacturer is :)
thanks... next week i'll try the mod
really nice mod.....
well the odd thing is it says 4.1V now when its stockQuote:
Originally Posted by persivore
here is what Im thinking of getting:
25 turn bourns inc pot, 10k 0.5w 10% tolerance
4.7k panasonic carbon film 1/4w 5% tolerance (1/6W 5% by yageo available)
15k panasonic carbon film 1/4w 5% tolerance (1/6W 5% by yageo available)
100uf panasonic electrolytic or tantalum (ceramic are a problem :( ) 6.3v sourface mount (smd-smt) 105deg C
(radial or higher V or higher C available)
price is about the same on all I just want to get the best for the project
by the way Ive noticed something I dont get, most caps say 1000/2000hours ? is that max hold time ?
actually all those specs I listed for the opamp were all for LM358 opamps, thats why I was so confused :)
Im thinking
http://www.digikey.com/scripts/DkSea...=64805&Site=US
or
http://www.digikey.com/scripts/DkSea...=81333&Site=US
Thank you very much for all your help and again I appologize for the number of questions
Dan
ok, the mod works for me.
I used 1/4 W resistors 5% tolerance and a 100nf Ceramic Cap.
Now the voltages are stable, rock solid.
When i choose, for example 3.3v, this voltage permain all over the 32mb spi.
I incresed the mem freq. at 4mhz.
Thanks You very much from italy :D
bye bye
I did the mod yesterday.It's working stable as concrete :) Mys system is MSI NEO2 Platinum,2 sticks of 512 mb A-Data DDR600 TCCD and winnie at 2650 mhz.Before the mod,things were horrible.Blue screens under heavy load,sudden restarts without any reason coz of voltage drops.Now this mod settles my system to work flawlesly.Big thanks for this nice mod. :toast: :clap: :clap:
Hi
I finally got around to doing the mod, but now the booster is acting very odd
I powered it on without plugging it into the dimm to check if it works and the display is throwing some very odd numbers, its either showing stuff like 0.1-0.3 or crazy numbers up to 9v
is it supposed to do this if its not plugged into the dimm ???
Thank you
Dan
P.S. at first I thought I screwed up the mod so I double checked everything, even redid half the mod, but same thing :(
Hi
guys I need some help, I recently modded my booster using the basic mod, but before sticking it into the dimm I decided to check if its aok, I plugged the power connectors in and while holding the booster in mid-air I powered on the pc, however now the booster's display shows some really strange numbers, its either something like 0.1-0.3 or they jump around all the way up to 9v
can someone, who has modded their booster, please pull theirs and see if behaves in a similar way if its not plugged into the dimm ? thing is Im not sure if I screwed up the mod (even though I tripple checked everything and even redid half the mod just to be sure) or if the booster simply doesnt like running without being plugged into a dimm
please help, my bh5s really need more v :)
Thank you
Dan
It is impossible for the booster to output any more than the 5v rail, unless you start changing where the booster takes its voltage supplies from
The mod shouldn't effect the boosters reading at all. Does your PSU have a -5v line?
HiQuote:
Nope, didnt change anything, followed the basic mod pic very carefully and double checked it a few times. Did notice something, in the basic mod diagram both input voltages are 12v while in the pic one comes off the 12v and one off the 5v, which one is correct ?
Most of the time the booster showed 0.1-0.3v, so I tried to raise it by turning the VR, but it didnt change at all, it just kept turning, is a VR supposed to just turn and turn without end ? the one I got doesnt seem to have a min or max it just turns and turns (its a bourns 10k 25turn pot, the small factor type)
yep the PSU has a 0,5A -5V (its an antec true control 550)
Dan
In the basic mod, the 5v rail is used to produce a reference voltage.
With the complicated mod, the 12v rail is regulated down to 5v, and this is then used to produce the reference voltage.
Multiturn variable resistors don't have anything to stop them turning. You might be able to hear a click on some types, when they can't change resistance any more in the direction that you are turning :)
Can you measure the voltage at the middle pin/wiper of the variable resistor? The voltage there should change as you turn the variable resistor.
yes, but I was talking about the pic and diagram for the same mod, the basic oneQuote:
oh ok, I was a bit worried about that, havent had any experience with one of these before, last time I soldered something things were a bit bigger :)
dont have a dmm :(
will try to get ahold of one tomorrow and check
btw here is a pic of the front and back of my booster, let me know if anything looks off
the isolated parts are resistors, one 4.7k and one 15k, it doesnt matter which one is + and which one is gnd right ?
note this is my second revision, I changed the gnd points as the contact on the left was getting overloaded with wires and it was hard to solder, but that shouldnt have changed anything since both are just gnd
Dan
ok got a dmm
pin1 reads 0,80v, pin2 reads 2.42v, pin3 (middle) reads in between 0.8 and 2.42
what do you think ?
Dan
Are you sure that the 2 fixed resistors are connected correctly? The 15k should be connected to + and the 4.7k connected to ground.
yep, thats how they are, checked with the dmm a second agoQuote:
I do get 4.3 and 12 with the dmm, but thats just because they are on the circuit right ?
Dan
I know this thread is old and hardly anyone still uses DDR Boosters nowadays, but I thought I'd have a go anyway...
I've done the simple mod to my Booster without any fixed resistors (just got to be a little more careful) and it has lowered my overclock on my RAM. With the original Booster I could hit 230MHz on 3.2v, but now I can't get 220MHz stable at any voltage.
My RAM is 2 x 512MB sticks of A-Data PC2700 with BH-6 chips. This is quite a noisy PCB, so I was wondering if the modded Booster might be providing noisier power than an unmodded one? Is that possible?
Also, ZL1, did you ever get yours to work? It's just that you also run a P4C800, so it would be nice to compare notes :)
The stable voltage is nice, but the lower overclock is puzzling... Any help would be much appreciated!
Any updates..?
Did this today, havent tested it yet :D
http://i30.photobucket.com/albums/c3...s/PICT5194.jpg
http://i30.photobucket.com/albums/c3...s/PICT5193.jpg
