Originally Posted by charlie
No...you have to do it when you install OS, by pressing F5....
Wouldn't each time you re-run car low just wreck every other test?Quote:
no, thats what I did! And got all the Admin/Setup errors!!!Quote:
Originally Posted by SIOUX
C
hows it going kingpin? get any good runs yet? we are looking forward to seeing you make top of orb :D
ok....are you using a SATA disc???Quote:
Had a :banana::banana::banana::banana::banana: of a time last night. Lots of problems. Listen to this, I have a mobo that can run the cpu up to 3580 or so stable for pi and 3d with 14x:Quote:
Originally Posted by Geforce4ti4200
http://pic8.picturetrail.com/VOL256/.../100679318.jpg
Only problem is, it can't run mem over 261 stable NO MATTER WHAT vdimm or vagp.
Now I have another mobo that can run the mem to 275 stable @3.8vdimm/1.86vagp:
http://pic8.picturetrail.com/VOL256/.../101207804.jpg
,but only 3480mhz on cpu or so for pi and 3d, and not abit more mhz... NO MATTER WHAT:
http://pic8.picturetrail.com/VOL256/.../101207807.jpg
After getting nowhere all night and this morning, now out of ln2....:(
Def. not giving up, just need a little more time for testing. I really want to make 272-274x13 fly for 3d.
Looking good charlie. The LL ram will help your score out alot man. Also, I tested winxp vs win2k...and win2k was better for around 100 points or so in final score. I did all my testing at 200x13, 5-2-2-2 120-64-00 enabled, and stock card clocks/card timings for both OS's.Quote:
I swear, the longer I hang around computers, the harder I find it to explain them...are you sure that 13x w/01 is better than 14x w/11? I guess I was wrong about the WinXP. Now I'll have to try win2k out. Also tempted to claim my 15-20MHz back by using the 01 timing...hrm...lots to play with here.Quote:
Originally Posted by k|ngp|n
Your good lobby score is from the dram 11 setting, not winxp I promise :)Quote:
Originally Posted by Gautam
I have more testing to do still with that dram setting, I'll figure out the tradeoff.
Guess it looks that way. Those board issues are hella weird but I'm sure you'll iron em out.
It sounds sort of familar though. Back in 2003 or whatever, I remember people being able to hit 300MHz fsb easy with 2.4C's for example, but finding it impossible to do the same with the 2.6's and 2.8's (Assuming that the cooling wouldn't bind the CPU) something about the boards not liking the combo of high speeds and high fsb, you'd always have to pick one or other. Looks somewhat like what you've got on your hands.
wont higher fsb be better than higher cpu clocks? In many cases it is! Also wasnt your 44.4k without all the tweaks? Does your cpu and gpu still have more in it vs. your 44.4k?
I guess the question is is 14x250 with the 11 timing faster than 13x270 with the 01 timing.
Thats too bad to hear kingpin. Hopefully u can find the problem. Maybe condensation?
Nah. The chip just walls at 3486mhz for benching in one mobo, and can hit 3570mhz for benchmarks in another. Both are fully modded and tuned the same way. 3570mhz=p4c800-d and 3486mhz= p4c800-ed. The better mobo can run vcore stable up to 1.7v with no issues, and the other can only run stable up to 1.59v to 1.6v or so, then it clips out or freezes in windows. I've broken it down twice now to recheck my mods. I swithced vcore mod to diff one, havent tried it yet though. My problem lies somwhere in the v-reg im sure. If not for this one issue, this p4c-e is a killer board bench stable @275 with 5-2-2-2. This is not easy at all on this board/setup like it was with neo2 or dfi.. lol.Quote:
Originally Posted by moddolicous
think big....
Imagine the utter destruction and havoc this thing could wreak on the 01' orb @ 275x13 :P
Nice work k|ngp|n.
Hey, what volts you running the ATI core and mem?
What RAM you using and what volts?
so are you going to adjust your record predictions now m8Quote:
For the x850:Quote:
Originally Posted by uclajd
1.98v on the core/ 2.23v mem
I'm using buffallo tech 2700/3200 bh-5. It's speed setting are set as 2700, but the stickers on the ram sticks say pc3200. I'm pushing 3.8v thru them for 275.
Up or down? heh..Quote:
Originally Posted by Voodoo|Minion
Did some bs testing yesterday with the vdroop ciruit, and I found that vcore on this mobo was drooping alot more than others I tested and orignally though it was(.4-.5v). I was able to dial in the droop mod while running benches, so now I get .1 overvolt under load, and no droop at all. Alot easier and more effective to do it that way, then to just set vr at 28k or 27k and solder it in.
Going to grab some ln2 in a bit and taking another shot at 45k. Haven't given up just yet on #1.
Not 100% sure this will be the solution, but it's a good start.
wow what will it take for 46k then if your doing all that to go from 44.4k to 45k? Have you done all the windows tweaks? ;)
a new WR for 3d01 would be great, but still i'm waiting for the 50k :banana:
go get em kingpin, times almost up
good luck :)
Im really enjoying this... hope you will make it kingpin!
good luck kingpin....!!!! :woot:
wish you can get dothan to 3550+ with your p4c800-e now that you adjusted the droop mod.... :)
http://pic8.picturetrail.com/VOL256/.../101483039.jpg
77 points from OPP's SLI score and 1st overall....this was score was pretty hard to nail. Board is still not playing nice.
WOW!! Soooooo close... do you have an x800xtPE laying around?Quote:
C
yeah, but i need to mod it and prep it for ln2.
