Asetek micro, i really love this cooler, very good resultsQuote:
it is... I wish it would be easy to take out my waterloop to try one of those Vapochill Micro Extreme Edition and I would really like to see it vs a XP-90C .
what kind of temp do you get with it ? oc? voltage?
http://forum.hardware.no/index.php?a...ost&id=4594878Quote:
Originally Posted by JfRsQ
Everest translation from Norwegian:
Hovedkort = mainboard temp.
Nordsiden = chipset temp.
I think the Micro beats the XP-90 fairly easy
Some details of construction
http://forum.hardware.no/index.php?a...ost&id=4630896
ArcticOC, what kind of a fan(s) do you have blowing on your system?
Ambient 21ºC... Chipset (363 MHz) @ 27ºC... CPU @ 41ºC LOAD (2.9GHz, 1.55V [~1.595V real]) ... PWMIC @ 44ºC...
Either your sensor chip is 10ºC short in temp readings - or it's r e a l l y cold in norway.
Quick glance on reviews over Vapochill Micro don't give so very stellar impression about Micro:
Stock FX-57 @ 44-48ºC load
3.4GHz Northwood P4 @ 48-56ºC load
It`s quite cold in Norway :)Quote:
Originally Posted by largon
But when i runned the test it was approx 18deg c in my room. a temp diff of 4deg c from results. Used a 120mm fan blowin` on tha bastard
http://forum.hardware.no/index.php?a...ost&id=4594775
Hello, this is my conception of chipset cooling.
http://members.lycos.co.uk/elitar/chlodzenie/ch3.jpg
http://members.lycos.co.uk/elitar/chlodzenie/ch1.jpg
Temps plzzzzz
Sorry but i don't have screens at the moment ;(
Idle:~~39C
Stress:~~43-44C
at ~~3000rpm max 6500rpm
And it's very quiet alternative of stock cooling, efficient also :)
