I've done some looking around, and it looks like pin 7 on the 1571 chip is feedback. Can you check the voltage on the pin that I've marked to try to confirm this please.
when measuring on that leg i have the multimeter on 2V and it shows .979v and the multimeter on 20v it's 0,97v and it's sat on DC the multimeter?Quote:
Originally Posted by persivore
thats about what I expected :). Can you check the resistance between the same pin and ground please.Quote:
Originally Posted by chefnr1
measuring with the pc off it's show with MM on 2K=2,79k an with 20K=0,27K
Can you try soldering a 10k VR between pin 7 and ground.
Before you do the mod, find a voltage read point close to the area that the 1571 is in. I would expect that area on the card to be used for Vgpu, so look for a voltage which reads between about 1.2 to 1.6v. Make a note of this voltage, and check if it has increased at all after you have done the mod.
If that mods works ok, I'll look at Vdd/Vddq :)
Note: XS owners and members will not be liable for any damage caused to you or your hardware, neither can be liable for any breach of the warranty.
wow can you please give me an hint where to find a voltage read point because i have'nt a clue where to fin that??
and then i can set an reading point close to the end of the card as i use to do
Check around on the 3 MOSFETs at the back of the card or on the inductor on the front (looks like a black box with 1207-1R5 written on it in white) - there should be some exposed inductor leg either on the front or the back of the card.Quote:
yes the mod is done before voltage was 1.334v and after with a 10K vrpot it's 1.365v
and the measuringpoints are these on the mosfets iv'e been markt with white:)
http://upl.silentwhisper.net/uplfold...ringpoints.jpg
i tried to rise it too and it works:)
EDIT: And i forgott to say thanks persivore for the help you take youre time to do, and i hope you will help with the vdd/vddq modd aswell :stick:
Can you check the resistance between pin 7 and ground on each of the other 1571's. I can mark pin 7 on a picture for you if you if you can get a closer pic of the other chips :)
yes i will take a closer pic if i can get it closer than before, but the batteri are on charge now so i have to wait a few houre :(Quote:
heres the pic of the chip but that i markt with a ring is not 1571 it's show I and some strange sign and a R ,327H, 7Y6A , F730 you can see it if you look on it the other in the mittle i cant take a pic of i have insulation on that now because i have my singel stage on it well heres the pic..
http://upl.silentwhisper.net/uplfold...7/PICT1139.jpg
I've marked pin 7 on the attachment :)
the chip on the left shows with MM on 2K .532K and the other chip shows nothing att that leg :(
Sorry, I got the wrong pin for the chip on the right. I've marked the correct pin in green :)
For the chip on the left, connect a 10k VR between pin 7 and ground. I don't know which voltage it controls tho, but it will be either Vdd or Vddq.
i've allready measure that pin and it starts at .530K and then accelerate to .986KQuote:
for that chip, connect a 20k VR between pin 7 and ground.Quote:
witch is vdd and vddq of these two chips, and where do i measure the volts on it???
I don't know which chip will be for Vdd or Vddq. You should be able to get voltage readings for the 2 voltages from the indictors near the regulators (black cylinders with copper wire wrapped around). Vdd/Vddq should be about 2v on the card.
ok i'll test measure them and se what volt they give me...Quote:
EDIT: they both give on the on each two solder pints 2,3v and 2,5v exacley on both, hehe hard to say wich is wich :)
http://www.vihanepc.com/margusser/x700.jpg
where that v-mem point? :D
vgpu is already done... http://www.vihanepc.com/margusser/x700pro%20800x600.jpg
WOW havent things changed in the last 1.5-2 years . I am currently between cards and am back on my old x700 pro , could someone summarise the volt mods on this card or point me to where they may be .
:up:
