hi,
I would know what's the max memtest of OPB and others who is in 2*512 and at 2.5-3-3-5?
because I have a kit of centon pc3200LL and the first stick is ok at 315 and the second at 310 each one in single. what could it make?
thanks.
hi,
thanks.
DFI nF4 Ultra-D / Bios 310 / air cooling / Winchester 3000+ (CBBID)
300x8 / 2x512 MB G.Skill 4400LE (TCCD440)
DDR600 8-4-4-2.5-1T 2.8V
- Spi 32MB stable
- 6h Gold Memory normal test stable
- 10h memtest86+ stable
- Prime small fft / in large stable
- S&M cpu/memory test stable
Screen:
http://img39.echo.cx/img39/2678/300x8spi32mb8wh.th.jpg
http://img39.echo.cx/img39/9008/300x8prime23to.th.jpg
http://img39.echo.cx/img39/4015/300x8prime2gs.th.jpg
http://img39.echo.cx/img39/3743/300sandra3ih.th.jpg
flu1: memtest dos is a lot less stressful than other testing programs because it ONLY tests your ram.....you will be able to memtest in dos a lot higher than you will be able to run windows stable !!
if you can do superpi32m @ 310 2.5-3-3-x and run windows memtest you will have the best 2 sticks of ram i have seen on any forum in a long time !!!
G-Skill PC4400 'LE' 440 Chips on BP PCB! @ 2.5-3-3-7 2ith 2.9V + 0.03V (2.96V BIOS)..
http://www.thunder-keep.co.uk/site/h...igo/277x10.jpg
This is NOT the best speed achived, I have memtested at 285Mhz @ 2.5-3-3-7 @ 2.96V but I am running the CPU in.
With 3V I *Should* get 290 stable!
Concorde
not to be a stickler but you need to pass superpi32 to join in the fun!!
NOW... Here's the catch! If you think that SuperPI 1M-8M or Sandra are a sign of stability, then don't even bother showing it to us... There are many other threads more suitable for that kind of "stunts" in Xtreme Bandwidth forums.
So, for instance, if you have a set of TCCD that breaks DDR600 barrier @ 7-3-3-2.5-1T w/ SPi 32M and min. x7 multiplier then don't hesistate and bring it here... It would be very appreciated if you could add Sandra and A64Tweaker screens at same exact settings that forementioned SuperPi run was made... Just to give others an idea how to make theirs TCCD perform stable at higher speeds
Oh come now, 4 hours of BOINC not enough!
Got tests coming up, so give me a week to 32mb at my highest 2.5-3-3-7 speed.
Concorde
@Concorde RulesQuote:
Originally Posted by Concorde Rules
Just like arctic-k20 said above...
SuperPi 32M only in this thread, please. Not interested in anything else ;)
@eraser
Is that DFI NF4 board?
@XiN
I'm pretty sure you can take those sticks higher (for Spi 32M run) if it's Pime95 stable @ same speed as Spi 32 you posted ;)
Thanks guys :toast: The list is getting longer. Waiting for more :thumbsup:
i got 325 stable with my winni @ 2,5 4 3 6
with the venice my mem only does 310 @ 2,4 4 3 6
both @ 2,9 v......
i will take an stupid screen @ only 310 later when my water cooling arrives
Just for Xtra Info: did the same, (dif dfi (refurb.)board and cooling in bsmt pcp510 20pin, prepping this one for my wifes puter :hehe: ) replace GBLE w/ GBLAQuote:
Originally Posted by mad mikee
Will try for more b4 going through the screenie hell again.
Yes its DFI NF4 UltraD :toast:Quote:
Originally Posted by bachus_anonym
Yes they are prime stable at same speed ... but unfortunely memory controller (my 3000+ is a CBBID :\) is bad and infact I can't go above 300 ... I have tested many configurations at 305/310/312/315 (with 2.8V/2.9V/3.0V) but it doesn't finish spi 32MB :(Quote:
UPDATE 1:
Uhm, a little improvement
DDR600 7-3-4-2.5-1T
http://img122.echo.cx/img122/1262/30...32mb1kv.th.jpg
UPDATE 2:
With bios 510-3 I have broken 300 mhz barrier :toast:
310x7 | Bios 510-3 | Vdram: 2.83V
DDR 620 8-4-4-2.5-1T
http://img178.echo.cx/img178/2446/dd...32mb4kn.th.jpg
bachus_anonym, you can edit my result :D
edited to combine three consecutive posts - bachus_anonym
Got to 305 100% stable, going higher as we speak but its getting tough. dfi nf4 ultra-d 310 bios 2.91 volts, i think the chips are getting hot, as the only thing blowing on them is my xp-90
Edit: forgot to say, g.skill pc4800 2*512 with 440 chips.
Excuse me for too many posts, but I have done another personal "record"
DFI nF4 Ultra-D | Air cooling | bios 510-3 | 315x7
DDR630 7-4-4-2.5-1T SuperPi 32M stable :toast:
http://img273.echo.cx/img273/3122/ddr630744259pe.th.jpg
that is my gskill la 440 chips, sli-dr and fx55 0442
320x9 - 2.5-4-3-7 - and its can pass the tests but is not 24/7 stable.
305x9 - 2.5.4.-3-7 - is 24/7 for me :)
http://valid.x86-secret.com/show_oc?id=18852
Seems as though it might be TCC5, but is that ok? :P
DDR 600 @ 2.5-4-3-5 x8
I'll try for my 300x9 once I get my water :P
@cupra,
I'm sorry man, but SuperPi 32M is neccesary ;)
@justwOo
TCC5 is fine too as long as I see 32M ;)
Sorry forgot to take a Cpu-Z But
DDR600 2.5-4-3-5 300x8
http://i7.photobucket.com/albums/y28...600spi32mb.jpg
Not prime stable. But manage OCCT:D
OCCT is nice for a quick test.
http://i7.photobucket.com/albums/y29...2MBpi_occt.png
Since I sold these bad boys to Major this week I figured why not give them one last push to see if I could still reach 316MHz and maybe a little more. :D So I pulled out everything in my bag of tricks and this resulted in a new personal best of 321MHz :slobber: that's DDR642 for anyone a little slow. ;) It was about an 6 hour straight tweak fest but I'm happy with the results. I'm almost sad to see these guys go but atleast I know they're going to a good home. Hope you enjoy Major! :p:
http://img274.echo.cx/img274/779/ram3210ee.jpg
G.Skill 4400 LE 2x512MB (437 chips) http://picserver.student.utwente.nl/.../picserver.gif
These are the new OCZ Plat. Rev 2 TCC5. After weeks of trying all different bios and settings, this is the best I can do. Using 5/10-2 bios
i have 2x512 mb adata vitesta ddr566 and they cant run over 275 (2,8v) stable i have used 2,5-4-3-7 ,3-4-4-8 and same results, cpu is windy 3000 0450 2,6ghz@1,55 prime stable mobo: gigabyte nf4-4x GA-K8NF-9 s939
any help or those sticks are so bad?
Please update my results in the first post with my new results from a few post up thx! :toast:
@Opteron96
Your recent result is just unreal! 32M @ 310 6-3-3-2.5-1T with 2x512MB is something, that I'm not sure anyone has ever done before. Don't get me wrong, but I need to think about this result a bit. I might need to come up with some sort of verification for that. Don't take it personal, OK?
Other than that, list is UPDATED!
Unbelievable how can be only 3 entries in the 2x512MB - Trcd 3 section. This is my small contribution to this section. I will update it since I know I can do more but have no pics atm.
Rig:
- 2x512 GSkill 4400 LE 440 TCCD chips (actively cooled)
- winchester 3500+ CBBID 0451 (cooled by XP120+190CFM Delta)
- DFI NF4 Ultra-D
http://img282.echo.cx/img282/3010/27492hn.th.jpg
