Some tidbit for you MrRoadster :D
http://www.vr-zone.com.sg/?i=1582
Dunno if it will help you :)
big thanks , waiting for my new 6800u ;)
Thank you for your guide! I think the "force my cards to run at 3D speed all the time to bypass throttling" is the best tip ever :)Quote:
Originally Posted by LardArse
What I don't see in your guide is how to deal with the power problems. I can see in your pics that you use multiple psu's. Did you made them work together by connecting the green wires? Or do they operate separately?
Anyone know if you can flash other 6800's with Asus bios to avoid the throttle issue? :confused:
Powered by a generic power unit each. Just shorted the green and black for each, the cards' power turn on before the PC. Need to get new/mod the units, 12v at 11.4v :(
I havent heard of any throttling issues with the PCIE cards, maybe they're not existant?
Got the 6800 cards to do the 608/1408 Dance! :banana:
Thats 704Mhz of DDR2 goodness :D
Closing in on 29K with the good and very old NewCastle 3800+
http://www.vr-zone.com.sg/Shamino/3dmscores/28894.JPG
http://service.futuremark.com/compare?2k3=3571242
Think the SLI takes up quite a bit of system power. My GT1 scores is significantly higher with 1 card than with 2 cards, over 10 fps of difference.
http://www.vr-zone.com.sg/Shamino/3d...gt1compare.JPG
Have you compared scores between 1 card and 2 Misteroadster? Did you experience this?
13K on 05 still a long distance away though...
woah nice... i thought you already pasted 30k for 3d2k3 ?
:toast:
That an excellent memory MHz, am I right in that with 2 gpu's needing feeding bandwidth memory speed has once again become as important as gpu speed ?
Regards
Andy
nice score, bench 3dmark05 and use an FX55:D
704mghz of gddr3 goodness, right?Quote:
and btw
:slobber:
Heh no way, if it was I'd be over 29K close to 30K already.Quote:
Originally Posted by zakelwe
Yeah DDR3... what was I thinking??
No i didnt have enough time to do this sort of tests.Quote:
BTW: your clocks are from another world compared to mines :D
i hope my next 6800U couple will be better :rolleyes:
Congratz :toast:
Arghhh!!!! Come on man gimme 6 pts more!!!
608/1440
http://www.vr-zone.com.sg/Shamino/3dmscores/28994.JPG
http://service.futuremark.com/compare?2k3=3574849
Just 2 more Mhz on the GPU mem would've done it!!!
Room is too warm from the benching, gotta retry it tomorow :D
Genius !Quote:
How did you get your memory so high?
wish I could take the memory off this deceased 6800GT I have and put it on my 9700 Pro.. lol :D
Vmod I think or mayb chilled water on mem :DQuote:
Originally Posted by HaLDoL
More "juice" is always welcomed ;)
How's the weather there today? Hope you be able to break some records tonight with your benches :)Quote:
