Ditto, need more than 1.7 for my ballistix to get to 260. 245 on 1.7 2.5.2.2.5 is bloody goodQuote:
Originally posted by goddh0r
Anyone tried on Asus K8N-E Deluxe yet? :)
I installed mine over the weekend. As expected works fine on the regular P4C800 Deluxe. You can use slot 2 or 4. I used 4 as its easier to see the LED readout. I did not test the upper limit of adjustment but it will do at least 3.3V fine.
I managed to get 243Mhz 1:1 2.5-3-3-7 stable (12 hours of Prime 95) on my OCZ 3700 Gold Rev 1 at 3.0V. I also managed to lose my SATA RAID array (neccsitating a windows re-install) by fooling around at 250Mhz 1:1 so as usual be careful!
What? :confused:Quote:
Gascogne: Would also very much like to know how the booster works with MSI K8N Neo2 Platinum.
I would know if someone have tryed the Booster on this mobo, and if it works :D , nothing more ;) .
Have anyone tryed them? :toast:
Im getting a booster this week, so I can give it a go on my mb and let you know. :)Quote:
Originally posted by Juspriss
What? :confused:
@Gascogne: Tnx! :toast:
Ocz booster works nicely with MSI K8N Neo2 Platinum. :)
you think...i buy that mobo and from a sponsor arrive to me the boosterQuote:
what is the max woltage on the msi k8n neo2 (soket 939) ??
Tnx a lot Gascogne! :toast:Quote:
Max in bios is 2.8v and I haven't tried max with the booster yet but Im doing 3.2V now with it and no problems at all. :DQuote:
Tested up to 3.4v with the booster and no problem there. :)Quote:
Just good to have some fan to blow some air on the booster like it says in the manual. ;)
We reviewed the DDR Booster.
http://www.hardwaredome.nl/reviews/view/11
Have fun with the review :)
Enybody got an idee how long it will take to have de booster back from rma,its now about 10day's away.
I got the K8NS Pro as well. I'm able to run super pi at 259 fsb 1:1 2-2-2-5 with my BH-5 in slot 3, booster in slot 1. No problem whatsoever. But I can't even bench 3dmark or aquamark past 218 fsb with the booster at any any voltage! Oh well, where's that soldering iron?Quote:
Originally Posted by mad mikee
Originally Posted by Soltani
Did anyone find out about this?
cause I just bought this mobo, and a great P4 cpu, so I would like to know i the OCZ booster works on this mobo ;)
Does the Booster work on the DFI Lanparty Nforce3 250Gb socket 754 ?
Yes i just tried it in my asus k8n-e and it works fine... tried all the way up to 3.4v so far.... hyperx is getting to hot at 260mhz 1:1 2,5,2,2, gotta dig out my 120mm delta to cool it off :)Quote:
Originally Posted by jiff
Has anyone tried the OCZ DDR Booster with the Asus A8V Deluxe (Rev 2.0)? I know that rev 1.02 is not compatible. Any info on the rev 2.0?
the booster works fine on shuttle an51r :)
Originally Posted by Manoj
Anyone? I would also like to know...
Here you are yuriQuote:
Originally Posted by yuri
SK8V at 4 volt benchstable OC !
btw: Its AMD WR in Superpi M8 :banana:
and nr 6. total:
http://www.biwa.ne.jp/~yok/838RANK-NEW.htm
Works on S754 K8NSNXP with 2 x 256MB & 2 x 512MB XMS3500 as well.
Currently typing with DDR Booster in Dimm 1 & 2 x XMS3500 in slots 2 & 3.
Thight squueze but it manages.
Funny thing is that the K8NNXP & K8NSNXP have the same layout but on OCZ's website, they say that you can only use 1 DDR with the Booster in place.
Could it be that the Corsair XMS modules heatspreaders are slimmer than the "other" heatspreaders??
Can't try with other brands as I don't have anything else but my beloved Corsair XMS BH5's.... :banana:
Has anyone tried this on an IT7 MAX2 board? I'm currently debating on whether i should upgrade or not atm. I have an old p4 1.8a running at 2.7 with air plus a few sticks of corsair (cmx256a-3200LL) that are bh5. My problem is i can't attain a high bus due to my x18 multiplyer. What chip can i buy relatively cheap that would get me up in the 200fsb range and how many volts can i push to these bh5 sticks with the DDR Booster? Thanks in advance.
http://members.cox.net/pnot/cpuz.jpg
http://members.cox.net/pnot/cpuz2.jpg
Howdy Gascogne.Quote:
Originally Posted by Gascogne
Do you use DC? Since Im curently waiting for my mems, I would like to knom which slots u have the booster in and the mems.
The best choice would be:
Slot 4:Booster
Slot 3:
Slot 2:512\____ DC
Slot 1:512/
Or how do you run it?
just incase anyones wondering.
the OCZ booster works great on the Gigabyte K8NS Pro.
works even better then the actual Vdimm mod.
I been able to hit 3.8 volts on the ram with little to no problem.
with my Vdimm mod, I can't load the OS past about 3.1 volts, but with the DDR Booster it loads just fine, even at 3.8 volts.
I found no problems with it one this board. good solid combination.
I would like to know this as well. MIght pick up the board soon.Quote:
Originally Posted by dutchman.pt
