I Pity the Fool that Trys To Break Into My House!
:hehe:, But Getting Back to Phase Change:
chilly1, Is that Enclosure(Environmental Chamber) similar to what we were talking about when I was Building My Cascade?:)
how are u gonna walk in a room thats - 100?
your blood wil freeze up :slobber:
lol...bleh...i dunno how far i can wal with 300 lbs of cascades nyways
pcice,
a room in ur house?....man...that would be so kick,
Body?:D Actually The enviro chamber is only 3' X 2' X 1' for the MOBO. It will be run at -50. The caps have issues below that temp. The cooling to the NB, memory, CPU and Video will be direct die.
Must be stuffing a DX coil in there for a box that big.
Dry N2 I take it.
You guys are designing an environmental chamber:D . A doubled skinned acrylic shell would work really well and you can cast one of those to your own measurements.
I assume the designs you are working on are double skinned, or a single skin with lots of insulation. But if the latter we wouldnt be able to see the insides:( .
Regards
John.
Lexan or plexi would be nice then I can etch a logo in the side and polish an edge and backlight the xtremesystems logo...
I'm going to have to be Happy ATM with what I can Build Now, but That sure sounds Sweet!:)
Right Now, need some Rest,
"To Sleep.........Perchance to Dream........":p:
http://hallowen.freehosting.net/hq18bts3.jpg
man chilly 1...ur art work are amazing!
thats a nice setup, can't wait for benchmarks!! :D keep up the good work :toast:
Thanks deloreanz,
I'm in the process of building the Third Stage ATM
(As you can see from the Pic).
Was Planing on using a Blend of R1150/R50 initially, But I think I may Just Try R1150 By Itself 'till I Test out the System under Load First!:D
You REALLY Don't want to Just Dive Into using these Flammable High Pressure Gases All at Once without using Proper Techniques/Safety Devices. ;)
I'm going to use a Expansion Tank/450psi Burst Valve that I made from a 3000psi Scuba Tank in the Third Stage Discharge "Just In Case" Things Go Wrong!:cool:
