My x800XL with a gutted Arctic Silencer 5, extended duct, and a panaflo U1A 80mm fan attached. :toast:
http://www.kalionzes.com/panacooler/panacooler2.jpg
Originally Posted by Andrew LB
That's so cool :D
The design of that cooler is supposed to have a fan INSIDE the plastic housing. Sitting on top like that will actually make it less efficient and probably make your card hotter. The air flow isn't supposed to be flowing down, but actually flows off the side of the fan.Quote:
dats one heck of a fan mounting on the silencer..wats the temp between stock n the modded panaflo on?
Do aircooled TEC's belong here too?
Anyway:
MOBO: Asus P5A
CPU: P200 @ Still working on it (Mobo won't post above 110FSB).
MEM: 128MB Mushkin PC150 Rev.3
Vid: Ti4200 with PEP66 and 60x38 Delta Screamer.
Cooling: PEP66 + 1cm Coldplate + 72W TEC + 80CFM Delta + Homegrown shroud.
http://members.chello.nl/~a.bax1/PCStuff/Shid.jpg
:p:
I never knew TEC's can be air cooled, i thought air is not enough.
ok i did some research and found that air cooled tec's are not really that good. What kind of temps are you getting?
http://busta.nbfl.net/random/new_computer/comp_1.jpg
http://busta.nbfl.net/random/new_computer/comp_2.jpg
http://busta.nbfl.net/random/new_computer/comp_3.jpg
Added some fans around hot areas, ie the RAM and the chipset.
http://busta.nbfl.net/random/new_computer/comp_5.jpg
http://busta.nbfl.net/random/new_computer/comp_4.jpg
That's right, it doesn't work as well as a watercooled TEC but it does work better than any real aircooling.Quote:
Originally Posted by comrad
With my Celeron 1.2 @ 1.6 full load temps are about 2-3C above ambient, idle temps are less than 10C.
I promised to cool a P4 3.8GHz with aircooled TECs to ambient temps, but since I'm building an AMD rig that won't happen anymore.
Now I'm gonna (try to?) cool a (probably) 3200+ Venice below ambient @ full load using aircooled TECs.
The whiney little 50mm~ fan on my Leadtek 6800GT was getting annoying so i stripped the card down to the bare heatsink and made a custom Plexi shroud/duct that i can attach an 80mm fan to. Much quieter + same cooling performance, OR louder and much better cooling performance - depending on which fan is used :woot:
http://i2.photobucket.com/albums/y3/...M/P1010159.jpg
http://i2.photobucket.com/albums/y3/...M/P1010160.jpg
http://i2.photobucket.com/albums/y3/...M/P1010161.jpg
busta`:........ WOW, best wire organization in the world.
TMM : nice mod man, i love it, looks well thought through
TMM thats a nice and neat setup you made, I love the ingenuity of the fan shroud, but I have to ask why not a 120mm fan or atleast a 92mm :D
This is my modded Arctic Cooling Freezer 64. Stock fan is dead.
http://img249.echo.cx/img249/4654/dsc005557xt.jpg
w00t, Card-board is for the best of modders. :D
http://img15.echo.cx/img15/5456/picture0223vz.th.jpghttp://img15.echo.cx/img15/6056/picture0232lo.th.jpghttp://img15.echo.cx/img15/4760/picture0247iz.th.jpg
Hell, well THAT is ghetto :toast:
Which fans are that btw?
Sunon 120's, 84cfm at 12v and 34dba. My computer is so silent as of lately, My case yields many more loud fans. :DQuote:
Originally Posted by ZMarre
ahhhhhhhh thats is fantastic, takes me back to the days between cases, cardboard all the way!!!
love it :D
ghettowned...... :woot: heres my case
http://img210.imageshack.us/img210/6109/blah0020rc.jpg
http://img210.imageshack.us/img210/3641/blah0010os.jpg
http://img210.imageshack.us/img210/6623/blah0040fn.jpg
http://img210.imageshack.us/img210/4243/blah0058ab.jpg
http://img281.echo.cx/img281/290/hpim03309bp.jpg
the front intake fan is held on by duct tape btw
:stick:
http://img39.echo.cx/img39/5236/pc11su.th.jpg
http://img39.echo.cx/img39/5593/pc20fq.th.jpg
http://img39.echo.cx/img39/3724/pc30vg.th.jpg
http://img39.echo.cx/img39/7991/pc49rv.th.jpg
http://img39.echo.cx/img39/351/pc54ao.th.jpg
http://img344.echo.cx/img344/465/15xn.th.jpg
http://img306.echo.cx/img306/8155/24el.th.jpg
http://img316.echo.cx/img316/9416/38nd.th.jpg
3 pics on end are my "upmarket ghetto" mem + mosfet cooling idea :banana:
It works.... :D
Nothing special but effective...PWMIC 42 and nF4 chipset 40 under prime95 blend.
http://img343.imageshack.us/img343/4...04356fg.th.jpg
How are you supplying it with 24-26v??? I need to know, my PC is so nearly a Hovercraft... Add a little remote control, and It'll fly round the front roomQuote:
Originally Posted by BigDov
I need piccies
Mine.....
http://img164.imageshack.us/img164/8897/phto00167dg.jpg
http://img286.imageshack.us/img286/3...00111mw.th.jpg
http://img286.imageshack.us/img286/4...00128hx.th.jpg
http://img111.imageshack.us/img111/8...00172bi.th.jpg
http://img111.imageshack.us/img111/3...00189pe.th.jpg
http://img111.imageshack.us/img111/6...00237ft.th.jpg
dats very colourful..n alot of fans
:D
my eyes hurt from al thsoe color and that bright HL2 wallpaper :P
Orange hurts your eyes??..and a white wallpaper too?......¬¬Quote:
Originally Posted by AzN_plyR
