hf :)Quote:
Originally Posted by notoriousformula
i should clean up that cable stuff.
but there is no need -> no window ;)
ive also added a lcd display. :)
hf :)Quote:
these 1/2" fittings look so amazing,
but not available in austria :(
1/4" mainly used
1/4 wow thats small why cant you just mod it for a larger size?
too much work, also there are no 1/2" tubes available.
but its true, 1/4" stuff doesnt look as mighty as the 1/2" stuff :D
1/4" ->
http://www.xtremesystems.org/forums/...783#post657783
caLume, I'm very sorry to bother you, but I am very intrigued by your rad. What are your system specs and what kind of temps do you get. I am very interested in a passive setup. Any info is greatly appreciated and sorry to bother you (Isent you two IMs but that is because I have never been able to talk to someone about a passive setup). I am excited to hear about your experiences. :)
... click ...
I love those compression fittings!
u got pm ;)Quote:
Originally Posted by hkhawk
hi :)
first of all, that rad is called mora2 ;)
http://www.ktc-cooling.com/catalog/p...products_id=55
now my setup
cpu: zern delta x
gpu: zern universal gpu wak
nb: ac twinplex (intel)
pump: eheim 1048
about temps.
i got full load nearly 50°C at cpu at 26°C ambient.
its totally passive.
the mora 2 owns, has a lot of power.
Very Nice setup :toast:Quote:
Originally Posted by tH3_b4iT
STILL UPGRADING ON THIS ONE
none of those links work
http://home.houston.rr.com/nettwerk/Lanboy/
Msi Neo 2 Platinum
3500+ 939 week37 (crap week) @ 2.6ghz (260x10 1.6volts)
1 gig Gskill - 2.5-3-3-10-1T
OCZ 550w PSU
2 - 74 gig raptor raid 0
2 - 200 gig maxtor drives
EVGA nvidia 6800U (460/1250)
SuperLanboy Case
Switftech Waterkit with Dangerden 6800 cooler
you sure play alot of game nettwerk :) Very nice and clean case keep it up :)
wow i rikee...
http://img.photobucket.com/albums/v1.../06_resize.jpg
http://img.photobucket.com/albums/v1.../04_resize.jpg
http://img.photobucket.com/albums/v1.../10_resize.jpg
http://img.photobucket.com/albums/v1.../11_resize.jpg
http://img.photobucket.com/albums/v1.../12_resize.jpg
http://img.photobucket.com/albums/v1.../13_resize.jpg
nice rig megadet
indeed, very nice rig !
this is my very first attempt of watercooling, and i'm very happy with it, considering i was working in such a small case!
pics are a bit rusbish as they were taken with my phone!
http://img.photobucket.com/albums/v2...Picture521.jpg
http://img.photobucket.com/albums/v2...Picture385.jpg
http://img.photobucket.com/albums/v2...Picture434.jpg
http://img.photobucket.com/albums/v2...Picture398.jpg
http://img.photobucket.com/albums/v2...Picture360.jpg
http://img.photobucket.com/albums/v2...Picture357.jpg
very small rad, which temps have you got ?
max under load of 45 which isn't great, but couldn't fit anything more inside :( might invest in a slightly bigger case soon!
what kind of radiator are you running jopers?
it came with an astek kit, that i bought of a mate, with some bits changed such as the barbes for thicker tubes and a different res!
aparently as i've been told the rad is a black ice pro
wow that last pic is amazing. shouldnt you run the pump to the rad then cpu though?
Thnx, it is the only way that works for my setup since my rad is outside my case. I have another 12" UV tube coming soon.
