Tell this to the 35W chip in meiner Mühle ;)Quote:
Originally Posted by GravdiggA
Seriously, I've got a 2400+ 35W 1.35V, and it does fine in my NF7. Not a great overclocker though...
http://www.fury-tech.com/images/user...3x10%2041secs%
2200+ Mobile @ 243x10 1:1
stock amd sink + 80mm tornado on the cpu.
ocz 3700 gold's.
stock nb sink.
Some eye candy ;)
258x10 1:1
262x9 1:1
The cpu cant do 2600Mhz with this cooling and I cant get over 262fsb, probably due to the fact of the rams ;)
These FSB settings are sick Bennah. What kind of cooling and vdd-settings are you using? Which motherboard, I think I'll buy one ;)
My XP-M2600+ does 3080MHz @ 220FSB & 2.25V.
Just today I was able to get a 232FSB stabile with the L12mod.
Bennah, what mobo and bios were you using for those clocks?
I suppose I shall post mine up. I've had it for a few months now.
xp2600+ mobile
IQYHA 0401 MPMW
does 2.7ghz stable at around 1.84v
Hit 2.75ghz benching, not sure about overall stability
sp-97 w/90mm smartfan
Mine fron the egg
mobile barton 2600+
IQYHA 0352 RPMW
2490@1,675v (237x10.5) I won't pust it more since it only use default air cooling :) at 55C
it prime stable for 1 hour
the rig used:
DFI LP-B
Mushkin PC3500 lvl II 2x256 DC @ 3,2v
DFI Infinity and the 1-31 bios.Quote:
Originally Posted by gouda96
No mods to it yet, but when I get my Intel stuff setup I'l have some time to mod it, any way possible. Probably droop mod and vdimm :D
my specs for my mobile is in my sig
nfII ultra infinity
2x256 ch-5 2-3-2-11
2500 IQYFA @ 11x230 = 2520mhz
1.79vcore 47°C (load) slk900a
which overclock the best ?
Product Name+ Price Shipping Ground Discount Free Rider 2nd Day Upgrade
AMD Mobile Athlon XP2400 35W Processor(Tray) (AQYHA:0430EPMW) $102.00 $5 N/A Full Free
AMD Mobile Athlon XP2400 35W Processor(Tray) (IQYHA:0402SPMW) $102.00 $5 N/A Full Free
AMD Mobile Athlon XP2400 Processor(Tray) (AQYHA:0415UPMW) $87.00 $5 N/A Full Free
AMD Mobile Athlon XP2600 Processor (Tray) (AQYHA:0431APDW) $105.00 $5 N/A Full Free
AMD Mobile Athlon XP2600 Processor(Tray) (IQYFA: 0350 MPMW) $105.00 $5 N/A Full $3
I choose between these two...but go for the 2600+ killer stepping there...
AMD Mobile Athlon XP2600 Processor(Tray) (IQYFA: 0350 MPMW) $105.00 $5 N/A Full $3[/QUOTE]
Now running 2650Mhz
With Mach II 3050Mhz
so older stepping better eh ?
Im pretty sure that the Aqyfa is the better choice between those two. not sure though.
have the batch numbers? lower# = better
Batchnumbers tell us nothing but what pga housing the die was mounted to :DQuote:
Originally Posted by saaya
They cannot say anything reliable about quality/position of the die on the wafer - imagine... what it would cost like to sort and pick out the best cores, give them numbers and then shipping them to malaysia for completing the cpu!
It's nonsense with the batchnumbers IMO :)
But that's my opinion ;)
P.S. Long time no see, Sascha :D
just got my mobile 2400+ 35 watt IDYHA installed will post when i have it running stable. Right now I just got it running at 9x200 1.45v gonna see what it can do. Might take m awhile b/c this is my first OC so any and all advise accepted :)
Zetachi
Hi zetachi, welcome to the sickness :D
Your cpu has a weird new stepping, at least for me. I am sure it does well.
It should at least do 2.2Ghz at 1.45V, the better cpus sometimes get to 2.5GHz at this kinda voltage. Be careful, make sure, your cooling can handle the heat, contact is great and you're using good thermal paste (for aircooling and water - Arctic Silver5 iirc).
Good luck, and please report your results here :)
i never tried 1.45 on my 2400+ 35w, ive never seen that steeping before though, itll be interesting.
on my 2600+ 45w i got 2.1ghz at 1.5, though that chip never broke 2.4 ghz and giving it more then 1.8 didnt help me, my 35w however did much better, but i started with 1.8v and went up.
im not familiar with that mobo so i can only hope that it will keep up even if its not on the best chipset... we will see...
http://doublescan.wz.cz/cpuz.gif
Mine AXP-M 2600+ does with 1.850Vcore 2700Mhz easily, could probably do much more, but... ;) That's more that enought for me.
http://doublescan.wz.cz/2600Barton_mobile.htm
My old AXP-M 2500+ do with the same 1.850Vcore just only 2550Mhz...
http://doublescan.wz.cz/2500Barton_mobile.htm
My O/C results suxx, I know. Im not good overclocker - silent PCs did not go overclock well, they constantly overheat :stick:
^dont you have watercooling?
shouldnt be that hot :p:
is 2.7 stable at that voltage? i konw my 2400+ 35w was stable at 2.65 with 1.85, i had it running at 2.7 with those volts for a very long time, never primed but never crashed either.
2600+ at 2500mhz 1:1 (250x10) at 1.65v :)
http://img5.exs.cx/img5/4628/2500mhz0jo.jpg
is that stable? if so then very nice clocks indeed!
35w?
if you are talking to me, then yes it is prime95 stable :) I even lower vcore to 1.6v and it ran fine but prime95 failed after an hour....however, I was using the comp at the same time for all my prime95 tests.
very nice, is that a 35w chip?
also, what cooling?
