Above mem clock/timings failed prime. Not surprising. It was from ryzen dram calculator which never worked on taichi x370 nor x399.
tested repeatedly same 16k iteration same exact cores.
http://www.xtremesystems.org/forums/...7&d=1574660334
Works on giga and more than likely asus since I think thats the brand the author uses.
Taichis always been odd man out and the natural response is to run looser but...you would be wrong. Hashing out manual profiles now for the board. Might be usefull to some endusers. Seems all the memory profiles that i built on x370/x399 port right over so that should save a crapload of time.
