This from a bit earlier in the thread looks plenty safe to me.
http://www.xtremesystems.org/forums/...=1#post5102202
To make it even more safe I suggest you improve on the mounting to make sure that the block itself cannot move much after mount with rubber and metal spacers.
However that is with water-cooling, with a heavy air cooler it will require that you do the same as above, but even more carefully.
